Context: hassio / appdaemon-addon / appdaemon API
For a small project I wanted to use the AppDaemon API to receive webhooks from various services over the internet to be able to ‘act’ on them. While setting this up I ran into the problem of the appdaemon API not being available/reachable and tried figuring out what was wrong here.
A few things that I concluded:
ad_port
in documentation should beapi_port
api_port
should be different from dashboard port (e.g. 5555) - appdaemon addon from https://github.com/hassio-addons/addon-appdaemon doesn’t support an option to open up another port to the host so that the API can be reached (only
5050
is available for the Dashboard). For that I had to create a custom appdaemon addon in my/addons
folder (by cloning the original addon repo mentioned earlier and changingconfig.json
to have an extra port option for the API to be reached on (seeports
section):
"name": "AppDaemon",
"version": "dev",
"slug": "appdaemon",
"description": "Python Apps and HADashboard for Home Assistant",
"url": "https://github.com/hassio-addons/addon-appdaemon",
"webui": "http://[HOST]:[PORT:5050]",
"startup": "application",
"boot": "auto",
"hassio_api": true,
"homeassistant_api": true,
"host_network": false,
"ports": {
"5050/tcp": 5050,
"5555/tcp": 5555
"map": [
"config:rw",
"share:rw",
"ssl:rw"
"options": {
"log_level": "info",
"commtype": "websockets"
"schema": {
"log_level": "match(^(trace|debug|info|notice|warning|error|fatal)$)",
"commtype": "match(^(websockets|sse)$)"
"environment": {
"LOG_FORMAT": "{LEVEL}: {MESSAGE}"
Hope this helps others in the future. I’m planning to post the project I’m working as well, so there will be some more context to this story.
