I’m having trouble getting audio to work. I see the hassio-audio container running, but checking the logs, I see
W: [pulseaudio] module-udev-detect.c: Failed to open /proc/asound/card0: No such file or directory
N: [pulseaudio] alsa-util.c: Disabling timer-based scheduling because running inside a VM.
E: [pulseaudio] main.c: Failed to acquire org.pulseaudio.Server: org.freedesktop.DBus.Error.AccessDenied: Connection ":1.90" is not allowed to own the service "org.pulseaudio.Server" due to security policies in the configuration file
E: [pulseaudio] bluez5-util.c: GetManagedObjects() failed: org.freedesktop.DBus.Error.ServiceUnknown: The name org.bluez was not provided by any .service files
s6-rc: info: service pulseaudio successfully started
s6-rc: info: service legacy-services: starting
s6-rc: info: service legacy-services successfully started
E: [alsa-sink-USB Audio] alsa-sink.c: ALSA woke us up to write new data to the device, but there was actually nothing to write.
E: [alsa-sink-USB Audio] alsa-sink.c: Most likely this is a bug in the ALSA driver 'snd_usb_audio'. Please report this issue to the ALSA developers.
E: [alsa-sink-USB Audio] alsa-sink.c: We were woken up with POLLOUT set -- however a subsequent snd_pcm_avail() returned 0 or another value < min_avail.
E: [alsa-source-USB Audio] alsa-source.c: ALSA woke us up to read new data from the device, but there was actually nothing to read.
E: [alsa-source-USB Audio] alsa-source.c: Most likely this is a bug in the ALSA driver 'snd_usb_audio'. Please report this issue to the ALSA developers.
E: [alsa-source-USB Audio] alsa-source.c: We were woken up with POLLIN set -- however a subsequent snd_pcm_avail() returned 0 or another value < min_avail.
s6-rc: info: service legacy-services: stopping
s6-rc: info: service legacy-services successfully stopped
s6-rc: info: service pulseaudio: stopping
[03:06:03] INFO: Service restart after closing
s6-rc: info: service pulseaudio successfully stopped
s6-rc: info: service alsa-init: stopping
s6-rc: info: service alsa-init successfully stopped
s6-rc: info: service alsa: stopping
s6-rc: info: service alsa successfully stopped
s6-rc: info: service legacy-cont-init: stopping
s6-rc: info: service legacy-cont-init successfully stopped
s6-rc: info: service fix-attrs: stopping
s6-rc: info: service fix-attrs successfully stopped
s6-rc: info: service s6rc-oneshot-runner: stopping
s6-rc: info: service s6rc-oneshot-runner successfully stopped
s6-rc: info: service s6rc-oneshot-runner: starting
s6-rc: info: service s6rc-oneshot-runner successfully started
s6-rc: info: service fix-attrs: starting
s6-rc: info: service fix-attrs successfully started
s6-rc: info: service legacy-cont-init: starting
cont-init: info: running /etc/cont-init.d/filesystem.sh
cont-init: info: /etc/cont-init.d/filesystem.sh exited 0
s6-rc: info: service legacy-cont-init successfully started
s6-rc: info: service alsa: starting
s6-rc: info: service alsa successfully started
s6-rc: info: service alsa-init: starting
[20:06:07] INFO: Adjust ALSA mixer settings for /dev/snd/controlC0
s6-rc: info: service alsa-init successfully started
s6-rc: info: service pulseaudio: starting
W: [pulseaudio] main.c: Running in system mode, but --disallow-module-loading not set.
W: [pulseaudio] main.c: Home directory of user 'root' is not '/var/run/pulse', ignoring.
W: [pulseaudio] caps.c: Normally all extra capabilities would be dropped now, but that's impossible because PulseAudio was built without capabilities support.
W: [pulseaudio] main.c: OK, so you are running PA in system mode. Please make sure that you actually do want to do that.
W: [pulseaudio] main.c: Please read http://www.freedesktop.org/wiki/Software/PulseAudio/Documentation/User/WhatIsWrongWithSystemWide/ for an explanation why system mode is usually a bad idea.
E: [pulseaudio] main.c: Failed to acquire org.pulseaudio.Server: org.freedesktop.DBus.Error.AccessDenied: Connection ":1.125" is not allowed to own the service "org.pulseaudio.Server" due to security policies in the configuration file
[03:15:31] INFO: Service restart after closing
[20:15:35] INFO: Adjust ALSA mixer settings for /dev/snd/controlC0
E: [pulseaudio] main.c: Failed to acquire org.pulseaudio.Server: org.freedesktop.DBus.Error.AccessDenied: Connection ":1.152" is not allowed to own the service "org.pulseaudio.Server" due to security policies in the configuration file
The line in particular that attracts my attention is
So, the device does exist if I login to the OS. But if I switch into the hassio-audio docker container, /proc/asound is completely empty. Pretty good chance that’s my issue. Any good hints on how to correct this? What’s really weird is if I do “ha audio info”, it sees the card and I can set it as the default/pick a profile, but I never see it show up in the container, even after doing “ha audio reload”.
