Hey guys,
My setup:
Pi4 - zigbee2mqtt - USB CC dongle - Hue bridge > Light
When I enter my hall or bathroom my light is turned on at 100% but between 00:30 - 06:00 I set brightness to 5% because I assume that if you walk at that time frame you don’t want bright light. Everything is working like a charm the problem is that the bulb light up at 100% and instantly decreases to 5% which is like a fast bright flash and then drops to 5%.
Anyone experience that issue. I assume that you cannot light the bulb at 5% but first, you light up in the last state and then a new state 5% brightness is applied which causes this flash. The problem is after 00:30 i can walk 2-3 times and its the same flash, so it’s not the last state issue it seems the bulb start at 100% every time.
# Bathrom light
- id: Bathroom_light_100
alias: Turn on bathroom light at 100% when there is movement
- platform: state
entity_id: binary_sensor.bathroom_occupancy
to: 'on'
- service: light.turn_on
entity_id: light.bathroom
brightness_pct: 100
- id: Bathroom_light_5
alias: Turn on bathroom lights at 5% at night
- platform: state
to: 'on'
condition:
- condition: time
after: '00:30'
before: '06:00'
brightness_pct: 5
