HASSIO boot loop port 1 entered disabled state
Hi my old installation has failed and I’ve installed a new one a couple of days ago.
I use a couple of scenes, automations and mqtt and xiaomi switches through the zigbee2mqtt plugin.
Everything went well for a couple of days but after triggering a xiaomi switch to activate a scene, the system crashed and fails to reboot.
Is there a way to save this system? also what is causing this issue?
I’m having the exact same issue. Had my system up and running for about 2 weeks now. Got a majority of my devices integrated outside of a few Z-Wave devices that I haven’t transferred over yet.
I came home from a few days away and noticed that my automations weren’t working and I couldn’t login to the GUI. I rebooted and the system is in a loop and behaving exactly like your image above. Hass seems to load and everything shows “ok” on boot, but then just starts looping.
Wondering if you made any progress at all or still stuck. I unfortunately don’t have any backups.
Sorry i haven’t resolved it. i have reinstalled the system and have bought another zigbee sniffer. Will update if system goes down again
I’m also experience this error. The error occured first time after restaring home assistant when updating my automations.
I’m running Hass.io 0.98. I can see that the Pi running hassio is connected to my router.
Having this same issue :confused: Did you guys ever figure it out?
I just set this thing up yesterday (RPi4), tried following along with a YouTube tutorial on setting it up for remote access with duckdns, updated the config file and hit restart and now this thing is a brick. I flashed my SD card and tried starting over. And now all I get is IPv6 wlan0: link is not ready’ and ‘power management disabled’ in the console log. I’m connected through ethernet though. If I try using Putty to connect it rejects the connection. I have no idea how to troubleshoot this.
Did anybody ever solve this? I’m still stuck and pretty much ready to throw in the towel with Hass
I’ve tried re-installing over and over but just the same every single time
cheers
Put me in the same boat! Have even tried all new hardware, uploading image on another computer, switching router and still no joy.
Would be wrapped if there was a fix. :confused:
New zigbee sniffer on new system appears to be going strong - 4 years
