Nope. Still the same issue with Sabrent usb sata adapter and Samsung EVO 840 SSD.
Have no other spare SSD available at the moment. Will try later one of documented working combinations maybe. (like Sabrent adapter + Kingston SSD.)
Damnā¦ maybe you are right. Multiple people in various topics report that the Sabrent adapter + Kingston SSD (A400, 120GB) is the magical conbination.
I also use the Kingston SSD however my adapter cable is this one:
StarTech.com USB3S2SAT3CB SATA to USB Cable with UASP (Amazon)
been running 6 weeks now without a single issue
Ups.
It seems that Kingston SSD (A400, 120GB) did the magic.
Iāve done a few trial system reboots w/o any problems.
Edit: Magic is partial only as powercut (raspberry power off) is still the issue until Iāve deleted bootcode.bin
from SD card.
So no SD card needed anymore with the Kingston SSD (A400, 120GB) + Sabrent adapter?
Empty SD card ( size of 2Gb) is still there, well at least in my case. I will test how it is without it later on.
Edited:
Tested a few times =>
- RPi does not boot (reboot) without empty SD card inserted.
- After short (a few secs only) power cut it does not reboot
- After long (from approx 20 secs up) power cut it reboots normally
On the step where entering lineā¦
# curl -sL
https://raw.githubusercontent.com/home-assistant/hassio-installer/master/hassio_install.sh
| bash -s -- -m raspberrypi3
ā¦ I get messageā¦
[Error] Please install jq first
Please advise on what I need to do to get past this.
Sory new to thisā¦ Installed using
sudo apt-get install jq
Doh!
Thanks for this tip - I had a power failure yesterday after 2 month running of SSD and my system would just not boot anymore.
Until that power failure, it always worked perfectly fine without any SD card and would boot straight of the SSD. For some reason it does not anymore.
I tried the bootcode.bin and timeout methods, but nothing happened. The empty SD card did the trick, it started booting of the SSD again.
Need to get some sensors on ZIGBEE back up and running now.
Now start the Hassio installation (the following is one long commandā¦ line wrapping happens) >
# curl -sL https://raw.githubusercontent.com/home-assistant/hassio-installer/master/hassio_install.sh | bash -s -- -m raspberrypi3
When attempting to execute the above, I get error
bash: line 1: 404:: command not found
Can someone please help? Thanks
That script is designed to install Home Assistant on a computer (in your case, a Raspberry Pi 3) with an existing linux operating system. That type of installation is known as Home Assistant Supervised.
Two weeks ago, there was a blog post announcing Home Assistant Supervised would be deprecated immediately. However, the community objected to it and the decision has been placed on hold, for further review. However, the documentation has been purged of references to Home Assistant Supervised and installation scripts have been removed. It explains why your attempt to use it resulted in a 404
message (i.e. not found).
An archived version of the installer script is available here:
Thanks Taras. Itād be a real shame to lose this Home Assistant Supervised as itās the only option that completely fulfills my requirements for using a RPi3B+. i.e.
- Allows me to boot from a Raspbian Lite USB
- Setup a static IP
- Setup WiFi
- Provides me with Supervisor control.
All the other installation options fall short in one way or another. My vote is to retain this option.
Thanks againā¦
Youāre welcome and youāre not alone in appreciating the advantages of Home Assistant Supervised. The development team did not have a comprehensive view of how many people use it. When it came time to lighten one memberās workload, they decided to end support for Supervised. It was only then, based on community feedback, did they learn that it was a valued installation method.
To gain better insight, version 0.110 now reports the precise āflavorā of Home Assistant (see Developer Tools > Info) and reports it back as telemetry via the updater integration. Updater is enabled by default (itās included in the default_config
option).
I fully agree, as I also failed to install HA supervised, showing up this 404 error. Very bad!
Just started to run HA to replace my pimatic installation or run it next to it. Without this option, HA is a dead horse for me, as I like to have full control of my pi and itās OS.
Please think about better options.
Best regards
Stefan
Hi all,
Iāve been running HA on an SSD since discovering this and a few other threads back in 2019. Itās been working great. Even survided a few power outages. Read that upgrading the Supervisor past 3.7 will cause booting from SSD to no longer work.
Has anyone upgraded past that point? Iām concerned about falling to far behind. I canāt go back to an SD card as I had too many failures. I guess I would need to do VM but I have several USB conencted dongles (ZWave, Wyze etc ā¦) which make VMās more challenging to setup.
BTW Iām using Kingston SSD with the StarTech adapter.
where did you found this information??? Iām running on a ssd for some weeks now and in the last days i got serious thermal problems and iāve no idea why
Hi Yakman,
Well Iāve been running on SSD for a few months and always kept my system up to date. This morning I got a power outage and there we are, it is not booting anymore. So indeed I would hold on updating to the current version.
Right now my system is out and I donāt know what to do about it. I did not know that the latest supervisor would break the SSD boot. This I actually donāt understand as many must be running this configuration.
My house is now crippled 1 week away from vacation.
I was running Hassio 0.111.1 on a Raspberry Pi 3B with Sandisk SSD 128 GB. I even tried reboots in the past and all worked, so I thought it was settled.
Does anyone know how I could read the Hassio SSD to get the latest backup to an SD card?
Or any tips on getting the boot on SSD to happen? I was using an empty SD card or it would not work.
I think booting directly to USB on the Pi3 was a one way process, i.e. once done it will never boot from an SD Card - precisely why I never understood why anyone would! You could try a fresh RaspberryOS image and see if it boots.
If you have a Pi or Linux machine, it is highly likely you will be able to mount the SSD and read the data off it.
I recommend the Backup to GoogleDrive addon, but that advice is a bit lateā¦
Thanks for the advice.
Iāve inserted my previous SD card install and it booted correctly from there. So I have an old version of HASSIO running now, with missing devices.
Iāll try to mount the SSD on my PC and see if I can recover the snapshot. GoogleDrive is a good point, as soon as I get things running I need to look into it.
So I managed to mount my SSD on my PC and recovered the latest snapshot file.
I then transferred it to my running instance which uses the SD card and made a āWipe and Restoreā which worked beautifully. Everything is back, even the DECONZ configuration and Node Red flows.
The system still shows OS V3.12 - I clicked on the update button and it then downloaded and rebooted. After restart, the OS is still at v3.12. I canāt see why it does not update to 4.1 and was not able to trace anything in the logs. I cleared browser cache and still no updated OS. Any ideas? Where should I look to find out the issue?
Hardware: Raspberry Pi 3 Model B Rev 1.2
Supervisor Version: 227
Home Assistant: 0.111.4
Hassos 3.12
