Hassio breaks without reason
After fresh install since last break(not sure what caused that either), hassio were running without no new configuration for a couple of days. This morning i discovered it had breaked again. No accsess to hassio or samba… can this be home-assistant or rpi?
V.82.1
More data required.
Is the device on your network (ping)
Is port 8123 open? (nmap)
Is it possible to ssh in? (I assume you added the ssh addon, it is the first thing you should do on hassio)
If ssh is possible, what does the log say?
Ssh is not possible. I can see that only the red led on the rpi3 is on. I think it indicates that the sd card is unreadable
That is possible.
Something had wrecked my sd card for some reason. I bought a new one and hassio is now running again.
I wonder what will cause my next mysterious system breakdown. Well, well…
Most of these issues are either the SD-Card (Low Quality) or the Power Supply.
