hello, this morning I updated via hacs alexa media player and from that moment Hassio has not left anymore.
Going to the minipc I see the login and I can enter it with root and password. But I don’t know how to restore it.
Inside I have a backup of version 0.114 and I have not installed 0.115 because I mainly use lovelace floorplan and with the new version lovelace floorplan no longer worked.
Now since I stupidly didn’t download the screenshot I wanted to transfer it to a usb disk but I don’t know how to do it.
Could you help me by indicating the commands to mount the USB key and transfer the backup?
P.S. With putti I can’t log in with the same credentials I use to enter the minipc !!
Why ?
For what it’s worth, it works fine for me here (at least no differently to 0.114). The original not working is a known issue, but the Lovelace version should be fine.
Ok for floorplan but at the moment hassio is stopped and the only snapshot is above.
Now I think I have copied that backup on a stick but before reinstalling hassio on that pc I wanted to verify that I have copied the file correctly.
So I installed hassio on virtualbox.
My problem at the moment is to upload the snapshot that I have on the stick to virtualized hassio.
The big big problem is that I don’t know how to show the hassio virtualization stick and transfer the snapshot.
I’m almost desperate, if anyone can help me … Thanks
Alberto
P.S.
In the meantime, I attach the hassio start screen that I captured with my mobile. After this image it stops at login.
Entering the login with name: root and password: my password I do not see the commands ha xxxx
I solved … I don’t know how but I solved it.
I have deleted the entire contents of the tmp folder, restarted and hassio is now online.
I immediately copied the snapshot I had taken 6 weeks ago and made a fresh one and downloaded that as well.
I guess I’ll download every snapshot I create from now on: D
