Hassio - can not start
After reboot - hassio’’ is not starting - > ‘hasssio.local:8123’.
Also ‘ssh’ connection is refused…
The only I can see - folders/files via ‘network’ in Windows… See screen.
I can also access files. Also back-up folder
Can be something repaired… ? Is that some safe way to repair ‘hassio’?
Log is showing - as below.
Strange - but I can access ‘home panel’-> ‘http://hassio.local:8234
2019-10-14 19:42:55 WARNING (MainThread) [homeassistant.core] Unable to remove unknown listener <function EventBus.async_listen_once.<locals>.onetime_listener at 0x72a488a0>
2019-10-14 19:42:55 WARNING (MainThread) [homeassistant.core] Unable to remove unknown listener <function EventBus.async_listen_once.<locals>.onetime_listener at 0x72a48bb8>
2019-10-14 19:42:55 WARNING (MainThread) [homeassistant.core] Unable to remove unknown listener <function EventBus.async_listen_once.<locals>.onetime_listener at 0x72a48ed0>
2019-10-14 19:42:55 WARNING (MainThread) [homeassistant.core] Unable to remove unknown listener <function EventBus.async_listen_once.<locals>.onetime_listener at 0x72a4b228>
2019-10-14 19:42:55 WARNING (MainThread) [homeassistant.core] Unable to remove unknown listener <function EventBus.async_listen_once.<locals>.onetime_listener at 0x72a4b540>
2019-10-14 19:42:56 ERROR (MainThread) [homeassistant.components.hassio.handler] Timeout on /homeassistant/restart request
Finally, after reading some advises, I was able to start…
What I did? Installed updated via CLI command line.
It took about 40 minutes…
But finally I was able to log-in via web interface…
Still not known what was causing the problem…
