Hassio check homeassistant configuration add-on errors with no logic
Hi All,
I am now using hassio version 0.99.3 and I want to upgrade to the latest version.
I installed the homeassistant configuration add-on and it show that the latest version is 3.1 of the add on.
See Here
After installing and testing I am getting so many errors of which I am not EVEN SURE there are any errors at all.
again I am using 0.99.3 so it should be supported by the addon with no issues.
Here is what i am getting:
Log
            sidebar-icon-color: #8E8E8E
            sidebar-selected-background-color: var(--primary-background-color)
            sidebar-selected-icon-color: #FCB800
            sidebar-selected-text-color: var(--sidebar-selected-icon-color)
            sidebar-text-color: #141414
            state-icon-active-color: #FDEAB0
            state-icon-color: #FCB800
            state-icon-unavailable-color: var(--disabled-text-color)
            table-row-alternative-background-color: var(--secondary-background-color)
            table-row-background-color: var(--primary-background-color)
            text-primary-color: #141414
          Navy Blue & Yellow: [source /tmp/config/themes.yaml:605]
            disabled-text-color: #4A5E84
            divider-color: #2D374D
            label-badge-background-color: #3E4C6C
            label-badge-red: #252D40
            label-badge-text-color: #FBFBFB
            light-primary-color: #FECA67
            paper-card-background-color: #252D40
            paper-listbox-background-color: var(--primary-background-color)
            paper-slider-active-color: var(--paper-slider-knob-color)
            paper-slider-knob-color: #FEB221
            paper-slider-knob-start-color: var(--paper-slider-knob-color)
            paper-slider-pin-color: var(--paper-slider-knob-color)
            paper-slider-secondary-color: var(--light-primary-color)
            paper-toggle-button-checked-bar-color: #FECA67
            paper-toggle-button-checked-button-color: #FEB221
            paper-toggle-button-unchecked-bar-color: #3E4C6C
            paper-toggle-button-unchecked-button-color: #6E81AA
            primary-background-color: #1F2635
            primary-color: #FEB221
            primary-text-color: #FBFBFB
            secondary-background-color: var(--primary-background-color)
            secondary-text-color: #FEB221
            sidebar-icon-color: #8192B6
            sidebar-selected-icon-color: #FEB221
            sidebar-text-color: #FBFBFB
            state-icon-active-color: #FEF5D8
            state-icon-color: #FEAA0A
            text-primary-color: #FBFBFB
      group: ?
      http: [source /tmp/config/configuration.yaml:14]
        api_password: xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
        base_url: https://xxxxxxxxxxxxxxxxxxxxx.xxxxxxxxxx
        ssl_certificate: /xxxxxxx/xxxxx.xxxxx
        ssl_key: /xxxxxx/xxxxxx.xxxx
      ifttt: ?
        key: XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX
      influxdb: ?
        component_config: ?
        component_config_domain: ?
        component_config_glob: ?
        database: hassio
        default_measurement: state
        exclude: ?
          domains: ?
          entities: ?
        host: xx.xx.xx.xx
        include: ?
          domains: ?
          entities: ?
        max_retries: 10
        port: xxxxxxxxxxx
        tags: ?
        tags_attributes: ?
        username: xxxxxxxxxxxxxxxxxxxxxxx
        verify_ssl: True
      input_boolean: ?
        zigbee_permit_join: ?
          icon: mdi:cellphone-wireless
          initial: False
          name: Allow devices to join
      mqtt: ?
        broker: core-mosquitto
        discovery: True
        discovery_prefix: homeassistant
        keepalive: 60
        port: xxxx
        protocol: 3.1.1
        tls_version: auto
      panel_iframe: ?
        tasmoadmin: ?
          icon: mdi:lightbulb-on
          require_admin: False
          title: TasmoAdmin
          url: https://xxxxxxxxxxxxxxxxxxxxxxxx.xxxxxxxxxxxxxxxx:xxxx
      script: ?
      timer: ?
          duration: 0:10:00
          name: Time remaining
Successful config (partial)
  http:
This is weird since I have nothing complicated there at all.
Is version 3.1 is the LATEST that I can use or there is a newer version of which I should install instead? since I saw logs with version 3.2.8?
Please assist me with my way of upgradeing to the latest version.
Thank you!
Remove api password from the http section.
THANK YOU SO MUCH!!! :clap::clap::clap::clap::clap::clap:
it is now OK
Log
starting version 3.2.8
[08:51:09] INFO: Don't worry, this temporary installation is not overwriting your current one.
[08:51:09] INFO: Installing Home Assistant: latest...
[08:51:09] INFO: Please be patient, this might take a few minutes...
WARNING: You are using pip version 19.2.2, however version 19.3.1 is available.
You should consider upgrading via the 'pip install --upgrade pip' command.
[08:56:56] INFO: Installed Home Assistant 0.102.2
[08:56:56] INFO: Making a copy of your configuration for checking...
[08:57:18] INFO: Checking your configuration against this version...
[09:10:13] INFO: **Configuration check finished - no error found! :)**
Is there a way to be able to install what I need to upgrade the pip?
I am using the hass.io with dockers version 0.99.3
Thank you!!!
You can’t, but they’ll upgrade the version in the container at some point I’m sure.
There is no need. You don’t install things in a running docker container.
Thank you!
