Hassio Cloud Integration with Alexa throwing errors in 0.98.2
I saw in the Release Notes for 0.98.2 that there was a fix for the Alexa State Report
However, I’m still seeing the below error in my logs, the only way to get rid of them is to disable the cloud: platform integration.
Wasn’t sure where to post this…
-Rob
2019-09-03 19:26:32 ERROR (MainThread) [homeassistant.core] Error doing job: Task exception was never retrieved
  File "/usr/src/homeassistant/homeassistant/components/alexa/state_report.py", line 45, in async_entity_state_listener
    hass, smart_home_config, alexa_changed_entity
  File "/usr/src/homeassistant/homeassistant/components/alexa/state_report.py", line 103, in async_send_changereport_message
    response_json = json.loads(response_text)
  File "/usr/local/lib/python3.7/json/__init__.py", line 348, in loads
    return _default_decoder.decode(s)
  File "/usr/local/lib/python3.7/json/decoder.py", line 337, in decode
    obj, end = self.raw_decode(s, idx=_w(s, 0).end())
  File "/usr/local/lib/python3.7/json/decoder.py", line 355, in raw_decode
    raise JSONDecodeError("Expecting value", s, err.value) from None
json.decoder.JSONDecodeError: Expecting value: line 1 column 1 (char 0)
Yes same here, there’s an issue logged:
Fixed for me in 0.98.3
