Starting since around 0.100, the Configuration Validation never finishes. It just sits there rotating at least half an hour. I searched the forum but didn’t find any topic relating to this exact problem.
I have no errors in my configuration and Hassio work just like normal. I have quite a substantial configuration with plenty of “split-up” files, but that has never been a problem before. Any ideas?
Did you find an answer to this? I also have a lot of split up files and am having the same issue.
Hi! I ran hassio su repair out of curiosity and all of a sudden the GUI configuration validation worked again. I have no idea why that fixed it. Before I figured this out I had to run hassio ha check, which worked fine.
Since just recently, the commands are:
ha su repair and ha core check
