Dear all,
I have this setup:
-raspberry pi 3 b+ with raspbian installed
-the system is booted from a usb HD (WD pidrive)
-hassio is installed and running in docker (I followed this guide GitHub - dale3h/hassio-installer: Hass.io Installer for Raspberry Pi 3 B+ (Raspbian Stretch Lite))
The problem is the outcoming connection, there is something strange… Some time it works sometimes no. I use the custom component called life360 for device tracking. But now I can use it because there is connection error, but i think is not a component error but general connection error.
This is the log file:
2019-03-27 09:26:11 WARNING (MainThread) [homeassistant.components.http] Configuring trusted_networks via the http component has been deprecated. Use the trusted networks auth provider instead. For instructions, see Authentication providers - Home Assistant 2019-03-27 09:26:22 WARNING (MainThread) [homeassistant.loader] You are using a custom component for life360.device_tracker which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you do experience issues with Home Assistant. 2019-03-27 09:26:28 WARNING (MainThread) [homeassistant.setup] Setup of influxdb is taking over 10 seconds. 2019-03-27 09:26:29 ERROR (MainThread) [homeassistant.components.sensor.yr] Retrying in 20 minutes: Cannot connect to host aa015h6buqvih86i1.api.met.no:443 ssl:None [Try again] 2019-03-27 09:26:33 WARNING (SyncWorker_17) [custom_components.life360.device_tracker] Ignoring: ConnectionError: HTTPSConnectionPool(host=‘api.life360.com’, port=443): Max retries exceeded with url: /v3/circles.json (Caused by NewConnectionError(‘<urllib3.connection.VerifiedHTTPSConnection object at 0x6ff2c670>: Failed to establish a new connection: [Errno -3] Try again’)) 2019-03-27 09:26:39 ERROR (SyncWorker_17) [custom_components.life360.device_tracker] get_circles: ConnectionError: HTTPSConnectionPool(host=‘api.life360.com’, port=443): Max retries exceeded with url: /v3/circles.json (Caused by NewConnectionError(‘<urllib3.connection.VerifiedHTTPSConnection object at 0x6ff94ff0>: Failed to establish a new connection: [Errno -3] Try again’)) 2019-03-27 09:26:55 ERROR (SyncWorker_14) [custom_components.life360.device_tracker] Suppressing further errors until OK: get_circles: ConnectionError: HTTPSConnectionPool(host=‘api.life360.com’, port=443): Max retries exceeded with url: /v3/circles.json (Caused by NewConnectionError(‘<urllib3.connection.VerifiedHTTPSConnection object at 0x72fc7f50>: Failed to establish a new connection: [Errno -3] Try again’))`
And this is hassio log:
19-03-27 08:22:36 INFO (MainThread) [hassio.host.apparmor] Load AppArmor Profiles: {‘hassio-supervisor’}
19-03-27 08:22:36 INFO (MainThread) [hassio.host.services] Reload local service hassio-apparmor.service
19-03-27 08:22:36 INFO (MainThread) [hassio.utils.gdbus] Call org.freedesktop.systemd1.Manager.ReloadOrRestartUnit on /org/freedesktop/systemd1
19-03-27 08:22:36 INFO (SyncWorker_1) [hassio.docker.interface] Attach to image homeassistant/raspberrypi3-homeassistant with version 0.90.1
19-03-27 08:22:38 INFO (MainThread) [hassio.addons.git] Load add-on /data/addons/git/a0d7b954 repository
19-03-27 08:22:38 INFO (MainThread) [hassio.addons.git] Load add-on /data/addons/core repository
19-03-27 08:22:38 INFO (MainThread) [hassio.addons] Load add-ons: 53 all - 53 new - 0 remove
19-03-27 08:22:38 INFO (SyncWorker_4) [hassio.docker.interface] Attach to image hassioaddons/node-red-armv7 with version v2.0.2
19-03-27 08:22:38 INFO (SyncWorker_3) [hassio.docker.interface] Attach to image hassioaddons/influxdb-armhf with version v1.3.0
19-03-27 08:22:38 INFO (SyncWorker_1) [hassio.docker.interface] Attach to image hassioaddons/unifi with version v0.7.1
19-03-27 08:22:38 INFO (SyncWorker_7) [hassio.docker.interface] Attach to image homeassistant/armv7-addon-mosquitto with version 4.1
19-03-27 08:22:38 INFO (SyncWorker_8) [hassio.docker.interface] Attach to image hassioaddons/ssh-armv7 with version v4.0.2
19-03-27 08:22:38 INFO (SyncWorker_5) [hassio.docker.interface] Attach to image hassioaddons/glances with version v0.2.0
19-03-27 08:22:38 INFO (SyncWorker_6) [hassio.docker.interface] Attach to image hassioaddons/grafana-armv7 with version v2.0.1
19-03-27 08:22:38 INFO (SyncWorker_0) [hassio.docker.interface] Attach to image hassioaddons/ide-armhf with version v0.8.0
19-03-27 08:22:38 INFO (SyncWorker_11) [hassio.docker.interface] Attach to image homeassistant/armv7-addon-samba with version 8.1
19-03-27 08:22:38 INFO (SyncWorker_9) [hassio.docker.interface] Attach to image homeassistant/armv7-addon-duckdns with version 1.6
19-03-27 08:22:38 INFO (MainThread) [hassio.updater] Fetch update data from https://s3.amazonaws.com/hassio-version/stable.json
19-03-27 08:22:44 WARNING (MainThread) [hassio.updater] Can’t fetch versions from https://s3.amazonaws.com/hassio-version/stable.json: Cannot connect to host s3.amazonaws.com:443 ssl:None [Try again]
19-03-27 08:22:44 INFO (MainThread) [hassio.snapshots] Found 1 snapshot files
19-03-27 08:22:44 INFO (MainThread) [hassio.discovery] Load 1 messages
19-03-27 08:22:44 INFO (MainThread) [main] Run Hass.io
19-03-27 08:22:44 INFO (MainThread) [hassio.misc.dns] Start DNS port forwarding for host add-ons
19-03-27 08:22:44 INFO (MainThread) [hassio.api] Start API on 172.30.32.2
19-03-27 08:22:44 INFO (MainThread) [hassio.addons] Startup initialize run 0 add-ons
19-03-27 08:22:44 INFO (MainThread) [hassio.addons] Startup system run 1 add-ons
19-03-27 08:22:44 INFO (SyncWorker_14) [hassio.docker.interface] Clean homeassistant/armv7-addon-mosquitto Docker application
19-03-27 08:22:47 INFO (SyncWorker_14) [hassio.docker.addon] Start Docker add-on homeassistant/armv7-addon-mosquitto with version 4.1
19-03-27 08:22:49 INFO (MainThread) [hassio.services.mqtt] Set core_mosquitto as service provider for mqtt
19-03-27 08:22:49 INFO (MainThread) [hassio.discovery] Duplicate discovery message from core_mosquitto
19-03-27 08:22:52 INFO (MainThread) [hassio.addons] Startup services run 8 add-ons
19-03-27 08:22:52 INFO (SyncWorker_10) [hassio.docker.interface] Clean homeassistant/armv7-addon-samba Docker application
19-03-27 08:22:52 INFO (SyncWorker_12) [hassio.docker.interface] Clean hassioaddons/grafana-armv7 Docker application
19-03-27 08:22:53 INFO (SyncWorker_17) [hassio.docker.interface] Clean hassioaddons/ide-armhf Docker application
19-03-27 08:22:53 INFO (SyncWorker_14) [hassio.docker.interface] Clean hassioaddons/unifi Docker application
19-03-27 08:22:53 INFO (SyncWorker_18) [hassio.docker.interface] Clean hassioaddons/influxdb-armhf Docker application
19-03-27 08:22:53 INFO (SyncWorker_19) [hassio.docker.interface] Clean homeassistant/armv7-addon-duckdns Docker application
19-03-27 08:22:53 INFO (MainThread) [hassio.host.alsa] Update ALSA device list
19-03-27 08:22:53 INFO (SyncWorker_7) [hassio.docker.interface] Clean hassioaddons/ssh-armv7 Docker application
19-03-27 08:22:53 WARNING (SyncWorker_0) [hassio.docker.addon] Glances run with disabled protected mode!
19-03-27 08:22:53 INFO (SyncWorker_0) [hassio.docker.interface] Clean hassioaddons/glances Docker application
19-03-27 08:22:54 INFO (SyncWorker_10) [hassio.docker.addon] Start Docker add-on homeassistant/armv7-addon-samba with version 8.1
19-03-27 08:22:57 INFO (SyncWorker_12) [hassio.docker.addon] Start Docker add-on hassioaddons/grafana-armv7 with version v2.0.1
19-03-27 08:23:00 INFO (MainThread) [hassio.auth] Auth request from core_mosquitto for pi
19-03-27 08:23:00 ERROR (MainThread) [hassio.homeassistant] Error on call https://172.30.32.1:8123/api/: Cannot connect to host 172.30.32.1:8123 ssl:None [Connection refused]
19-03-27 08:23:00 INFO (MainThread) [hassio.auth] Home Assistant not running, check cache
19-03-27 08:23:00 INFO (MainThread) [hassio.auth] Cache hit for pi
19-03-27 08:23:01 INFO (SyncWorker_17) [hassio.docker.addon] Start Docker add-on hassioaddons/ide-armhf with version v0.8.0
19-03-27 08:23:03 INFO (SyncWorker_7) [hassio.docker.addon] Start Docker add-on hassioaddons/ssh-armv7 with version v4.0.2
19-03-27 08:23:59 INFO (SyncWorker_0) [hassio.docker.addon] Start Docker add-on hassioaddons/glances with version v0.2.0
19-03-27 08:24:02 INFO (MainThread) [hassio.auth] Auth request from core_mosquitto for pi
19-03-27 08:24:02 ERROR (MainThread) [hassio.homeassistant] Error on call https://172.30.32.1:8123/api/: Cannot connect to host 172.30.32.1:8123 ssl:None [Connection refused]
19-03-27 08:24:02 INFO (MainThread) [hassio.auth] Home Assistant not running, check cache
19-03-27 08:24:02 INFO (MainThread) [hassio.auth] Cache hit for pi
19-03-27 08:24:04 INFO (SyncWorker_14) [hassio.docker.addon] Start Docker add-on hassioaddons/unifi with version v0.7.1
19-03-27 08:24:05 INFO (SyncWorker_19) [hassio.docker.addon] Start Docker add-on homeassistant/armv7-addon-duckdns with version 1.6
19-03-27 08:24:07 INFO (SyncWorker_18) [hassio.docker.addon] Start Docker add-on hassioaddons/influxdb-armhf with version v1.3.0
19-03-27 08:24:12 INFO (SyncWorker_13) [hassio.docker.interface] Clean homeassistant/raspberrypi3-homeassistant Docker application
19-03-27 08:24:24 INFO (MainThread) [hassio.api.security] /host/info access from a0d7b954_grafana
19-03-27 08:24:24 INFO (MainThread) [hassio.api.security] /addons access from a0d7b954_ide
19-03-27 08:24:24 INFO (MainThread) [hassio.api.security] /addons access from a0d7b954_glances
19-03-27 08:24:25 INFO (SyncWorker_13) [hassio.docker.homeassistant] Start homeassistant homeassistant/raspberrypi3-homeassistant with version 0.90.1
19-03-27 08:24:27 INFO (MainThread) [hassio.api.security] /host/info access from a0d7b954_ssh
19-03-27 08:24:28 INFO (MainThread) [hassio.api.security] /addons access from a0d7b954_glances
19-03-27 08:24:28 INFO (MainThread) [hassio.api.security] /addons access from a0d7b954_ide
19-03-27 08:24:30 INFO (MainThread) [hassio.api.security] /supervisor/info access from a0d7b954_glances
19-03-27 08:24:30 INFO (MainThread) [hassio.api.security] /supervisor/info access from a0d7b954_ide
19-03-27 08:24:32 INFO (MainThread) [hassio.api.security] /addons access from a0d7b954_unifi
19-03-27 08:24:32 INFO (MainThread) [hassio.api.security] /host/info access from a0d7b954_ide
19-03-27 08:24:33 INFO (MainThread) [hassio.api.security] /host/info access from a0d7b954_glances
19-03-27 08:24:33 INFO (MainThread) [hassio.api.security] /addons access from a0d7b954_unifi
19-03-27 08:24:33 INFO (MainThread) [hassio.api.security] /supervisor/info access from a0d7b954_unifi
19-03-27 08:24:34 INFO (MainThread) [hassio.api.security] /addons access from a0d7b954_influxdb
19-03-27 08:24:35 INFO (MainThread) [hassio.api.security] /homeassistant/info access from a0d7b954_glances
19-03-27 08:24:35 INFO (MainThread) [hassio.api.security] /host/info access from a0d7b954_unifi
19-03-27 08:24:35 INFO (MainThread) [hassio.api.security] /homeassistant/info access from a0d7b954_ide
19-03-27 08:24:35 INFO (MainThread) [hassio.api.security] /homeassistant/info access from a0d7b954_unifi
19-03-27 08:24:35 INFO (MainThread) [hassio.api.security] /supervisor/info access from a0d7b954_unifi
19-03-27 08:24:35 INFO (MainThread) [hassio.api.security] /addons access from a0d7b954_influxdb
19-03-27 08:24:36 INFO (MainThread) [hassio.api.security] /supervisor/info access from a0d7b954_influxdb
19-03-27 08:24:36 INFO (MainThread) [hassio.api.security] /supervisor/info access from a0d7b954_ide
19-03-27 08:24:36 INFO (MainThread) [hassio.api.security] /supervisor/info access from a0d7b954_unifi
19-03-27 08:24:36 INFO (MainThread) [hassio.api.security] /supervisor/info access from a0d7b954_glances
19-03-27 08:24:38 INFO (MainThread) [hassio.api.security] /host/info access from a0d7b954_influxdb
19-03-27 08:24:38 INFO (MainThread) [hassio.api.security] /homeassistant/info access from a0d7b954_influxdb
19-03-27 08:24:38 INFO (MainThread) [hassio.api.security] /supervisor/info access from a0d7b954_influxdb
19-03-27 08:24:39 INFO (MainThread) [hassio.api.security] /supervisor/info access from a0d7b954_ide
19-03-27 08:24:39 INFO (MainThread) [hassio.api.security] /supervisor/info access from a0d7b954_glances
19-03-27 08:24:39 INFO (MainThread) [hassio.api.security] /supervisor/info access from a0d7b954_influxdb
19-03-27 08:26:43 INFO (MainThread) [hassio.homeassistant] Detect a running Home Assistant instance
19-03-27 08:26:43 INFO (MainThread) [hassio.addons] Startup application run 1 add-ons
19-03-27 08:26:45 INFO (SyncWorker_16) [hassio.docker.interface] Clean hassioaddons/node-red-armv7 Docker application
19-03-27 08:26:53 INFO (SyncWorker_16) [hassio.docker.addon] Start Docker add-on hassioaddons/node-red-armv7 with version v2.0.2
19-03-27 08:26:58 INFO (MainThread) [hassio.tasks] All core tasks are scheduled
19-03-27 08:26:58 INFO (MainThread) [hassio.core] Hass.io is up and running
19-03-27 08:27:00 INFO (MainThread) [hassio.api.security] /host/info access from a0d7b954_nodered
19-03-27 08:28:04 INFO (MainThread) [hassio.api.proxy] Home Assistant WebSocket API request initialize
19-03-27 08:28:04 INFO (MainThread) [hassio.api.proxy] WebSocket access from a0d7b954_nodered
19-03-27 08:28:05 INFO (MainThread) [hassio.homeassistant] Updated Home Assistant API token
19-03-27 08:28:05 INFO (MainThread) [hassio.api.proxy] Home Assistant WebSocket API request running
How can I check the connection and solve the problem???
