I haven’t done anything unusual apart from update to 0.107.5 now it wont load GUI - I cant access putty but can access via Samba. If I pull power from RPI the GUI will load and stay stable for a short time. Here’s my log - any help appreciated.
2020-03-29 11:19:23 WARNING (MainThread) [homeassistant.loader] You are using a custom integration for hacs which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant.
2020-03-29 11:19:38 WARNING (SyncWorker_13) [homeassistant.components.influxdb] Database host is not accessible due to '404: {"error":"database not found: \"HomeAssistant\""}
', please check your entries in the configuration file (host, port, etc.) and verify that the database exists and is READ/WRITE. Retrying again in 60 seconds.
2020-03-29 11:19:42 ERROR (MainThread) [homeassistant.core] Error doing job: Unclosed client session
2020-03-29 11:19:43 WARNING (MainThread) [homeassistant.loader] You are using a custom integration for google_fit which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant.
2020-03-29 11:19:45 WARNING (LoopEnergy Event Thread) [pyloopenergy.loop_energy] Exception (will try to reconnect) - 'NoneType' object has no attribute 'add_job'
2020-03-29 11:19:45 WARNING (LoopEnergy Event Thread) [pyloopenergy.loop_energy] Retrying socket connection
2020-03-29 11:19:46 WARNING (MainThread) [homeassistant.components.incomfort] Setup failed, check your configuration, message is: 401, message='Unauthorized', url='http://192.168.0.55/protect/heaterlist.json
2020-03-29 11:19:46 ERROR (MainThread) [homeassistant.setup] Setup failed for incomfort: Integration failed to initialize.
2020-03-29 11:19:46 WARNING (LoopEnergy Event Thread) [pyloopenergy.loop_energy] Exception (will try to reconnect) - send disconnected (EOF occurred in violation of protocol (_ssl.c:2408))
2020-03-29 11:19:46 WARNING (LoopEnergy Event Thread) [pyloopenergy.loop_energy] Retrying socket connection
2020-03-29 11:19:49 WARNING (MainThread) [homeassistant.setup] Setup of evohome is taking over 10 seconds.
2020-03-29 11:19:53 ERROR (MainThread) [homeassistant.core] Error doing job: Unclosed client session
2020-03-29 11:19:53 WARNING (MainThread) [homeassistant.components.light] Setup of light platform flux_led is taking over 10 seconds.
2020-03-29 11:19:54 WARNING (MainThread) [homeassistant.components.sensor] Setup of sensor platform efergy is taking over 10 seconds.
2020-03-29 11:19:54 WARNING (MainThread) [homeassistant.components.sensor] Setup of sensor platform google_fit is taking over 10 seconds.
2020-03-29 11:20:01 ERROR (MainThread) [homeassistant.core] Error doing job: Task exception was never retrieved
File "/usr/src/homeassistant/homeassistant/helpers/entity_platform.py", line 368, in _async_add_entity
capabilities=entity.capability_attributes,
File "/usr/src/homeassistant/homeassistant/components/climate/__init__.py", line 181, in capability_attributes
self.hass, self.min_temp, self.temperature_unit, self.precision
File "/usr/src/homeassistant/homeassistant/components/climate/__init__.py", line 490, in min_temp
DEFAULT_MIN_TEMP, TEMP_CELSIUS, self.temperature_unit
File "/usr/src/homeassistant/homeassistant/util/temperature.py", line 31, in convert
raise ValueError(UNIT_NOT_RECOGNIZED_TEMPLATE.format(to_unit, TEMPERATURE))
ValueError: None is not a recognized temperature unit.
2020-03-29 11:20:02 ERROR (MainThread) [homeassistant.core] Error doing job: Task exception was never retrieved
