Hassio dashboard
I installed hassio and it installed 0.51.1 - had the hassio menu item on the left side. I updated HA to 0.51.2 using “hassio homeassistant update” now I don’t have that menu item anymore.
If I try to access “X.X.X.X:8123/hassio/dashboard” or “X.X.X.X:8123/hassio/store” I get error “404: Not Found”.
Anybody has any idea what’s the issue?
did you remove discovery: or hassio: from your configuration.yaml?
Yes, I did comment out discovery. I now added hassio and it works fine. Thank you.
Glad I could help
