I made some changes to config, checked they were OK, then restarted the server. Result is no response from Hassio, and black screen when I plug the pi into a monitor. I have the SD card but cannot see a way to view the logs. How to proceed with a post-mortem and resurrect the instance?
Do you have samba installed? If so you can check the log, edit the config file that is causing the issue and do an hard power reset to reboot the Pi.
Above is how i solved it when i messed up again
Try this https://home-assistant.io/developers/hassio/debugging/
You will be able to login and when you do a âdocker logs homeassistantâ you will probably see an error message
Fix the config (located in /resin-data/homeassistant or via the samba add-on) and restart with âdocker restart homeassistantâ
I ran into the same issues as youâvalidated the config through the UI, then restarted Home Assistant but the UI wouldnât load. Here are the steps I recommend checking to get your HA back up and runnning.
- If you have the Samba Share add-on installed, then you may be able to access your
\config
folder, even if the UI is not responding. Open thehome-assistant.log
and check for errors. If you spot one, update your .yaml files and go to step 2 - If you have SSH add-on installed, you may be able SSH and reboot from there. Follow the steps here if youâve never done it before. Once logged in, type the command âhassio host rebootâ to do a proper reboot.
- Depending on how many components you installed, reboot times range from a minute to a few minutes. Try logging into the HA UI after a few minutes.
- If your Samba share and SSH isnât working, thenâŚunplug/replug your Raspberry Pi from power and hope for the best!
Some things to be aware of:
- The Validate Config button under Configuration sidebar is not 100% reliable. I can think of five occasions where it reported âvalid configâ, but the HA logs show a failure to load the config. Continue using it, but follow my steps above if your HA UI isnât accessible.
- Do not use the âRestartâ button under
Sidebar >> Configuration >> Server Management
. It just doesnât work, and you will have to unplug and replug your Raspberry Pi twice to get the UI loading. To reboot properly, go toSidebar >> Hass.io >> 3 vertical buttons >> Restart Home Assistant
or login via SSH and use command âhassio host rebootâ
