HASSIO DNS Errors
I have been having issues accessing the “Supervisor” page from the UI, in a web-browser the Supervisor won’t load unless a hit refresh a few times, in the Android App it just won’t load at all. I have hassio_dns errors in journald;
[ERROR] plugin/errors: 2 none.local.hass.io. A: unreachable backend: no upstream host
The container is rebooting periodically and quite frequently it seems. I’ve ran a few checks;
ha dns info - looks fine
ha su repair - no change
ha dns reset - no change
Any ideas what could be the issue? I guess re-installing is an option but I’m keen to get to the bottom of the underlying cause.
Running the latest versions of core ( 0.115.6) and supervisor (245)
I’m also running into the same issue, if anyone can possibly chime in for some advice?
@joemadd3n did you find any explanations for this? I am seeing this too
[ERROR] plugin/errors: 2 none.local.hass.io. A: plugin/forward: no next plugin found
try this Supervisor 234 not supported on Raspbian GNU/Linux 10 (buster)? Per error log
This help in my case
Cool. Yeah that is it… fix is being worked on. https://github.com/home-assistant/core/issues/47635#issuecomment-795575896
