Hassio Docker/Addon Registry Broken?
Hi there,
I was just trying to update one my my hassio addons, and I realized any outgoing network call is failing with a 500/503. Problem persists for updating the hassio instance, as well.
Anyone else currently running into this?
STACK TRACE
18-06-24 22:53:57 INFO (MainThread) [hassio.addons] Startup application run 3 addons
18-06-24 22:55:21 INFO (SyncWorker_10) [hassio.docker.interface] Update docker 0.71.0 with homeassistant/raspberrypi3-homeassistant:0.72.0
18-06-24 22:55:21 INFO (SyncWorker_10) [hassio.docker.interface] Pull image homeassistant/raspberrypi3-homeassistant tag 0.72.0.
18-06-24 22:55:22 ERROR (SyncWorker_10) [hassio.docker.interface] Can’t install homeassistant/raspberrypi3-homeassistant:0.72.0 -> 500 Server Error: Internal Server Error (“Get https://registry-1.docker.io/v2/homeassistant/raspberrypi3-homeassistant/manifests/0.72.0: received unexpected HTTP status: 503 Service Unavailable”).
Seems to be back now. (I couldn’t access store either)
