Hi!
I try to update Hassio from 0.100.2 to 0.102.0
Whenever I press update, it will disconnect and go offline. However, when it reloads later it is still version 0.100.2 and asks me to update.
Any suggestions?
Check both the home assistant log and the supervisor log for details.
How do I find the supervisor log please?
19-11-21 16:14:06 INFO (MainThread) [hassio.homeassistant] Update Home Assistant to version 0.102.0
19-11-21 16:14:06 INFO (SyncWorker_18) [hassio.docker.interface] Update image homeassistant/raspberrypi4-homeassistant:0.100.2 to homeassistant/raspberrypi4-homeassistant:0.102.0
19-11-21 16:14:06 INFO (SyncWorker_18) [hassio.docker.interface] Pull image homeassistant/raspberrypi4-homeassistant tag 0.102.0.
19-11-21 16:16:21 INFO (SyncWorker_18) [hassio.docker.interface] Stop homeassistant application
19-11-21 16:17:21 INFO (SyncWorker_18) [hassio.docker.interface] Clean homeassistant application
19-11-21 16:17:22 INFO (SyncWorker_9) [hassio.docker.homeassistant] Start homeassistant homeassistant/raspberrypi4-homeassistant with version 0.102.0
19-11-21 16:27:25 WARNING (MainThread) [hassio.homeassistant] Don’t wait anymore of Home Assistant startup!
19-11-21 16:27:25 CRITICAL (MainThread) [hassio.homeassistant] HomeAssistant update fails -> rollback!
Do you have api_password
set under http:
in your config? If so, remove it.
I haven’t, checked that.
have done a clean version of config file, updated now
rebooted with old config file, all works but RfxTrx component.
