HassIO doesnt start
Last few days I have been seeing the same issue. I did a new install and it worked then setup all my devices restart crash. After two days of messing with it I found the issue occur after setting up device through integration. To resolve the problem I deleted two files entity_registry.yaml and .config_entries.json file. After I did that I seem to have no issues but now cant see my nest or google cast. If I try to set it up again it works fine but if i restart home assistant it wont come back up again until i delete those two files.
Supervisor 115 fixes this b0 issue according to Pascal the Dev! https://t.co/NoYE8cu2oC
Thank you! It seemed I automatically received the 115 supervisor. Then I ran the normal update command and everything works again. Yaaayyy :slight_smile:
Thanks everyone for helping!
Excellent. After I posted to you here I reached out to Pascal on Discord and he fixed it.
