Hassio doesn't start
After a manual power off / power on of my raspberry… my Hassio that worked fine after one year …do not start.
I have only a backup of the config folder.
Any suggestion before I reinstall all from zero???
Please help me!
Logs??? We are not psychic
how can I read logs?
I can access to it only via SSH with Putty
There is a log file when you ssh in. In the config folder.
Finally it restarted again!!!
I have a error:
ERROR (Recorder) [homeassistant.components.recorder.util] Error executing query: (sqlite3.DatabaseError) database disk image is malformed [SQL: 'INSERT INTO events (event_type, event_data, origin, time_fired, created, context_id, context_user_id) VALUES (?, ?, ?, ?, ?, ?, ?)'] [parameters: ('service_registered', '{"domain": "recorder", "service": "purge"}', 'LOCAL', '2018-12-16 08:30:18.764039', '2018-12-16 08:31:09.713962', '6e7051c7fe7d48f99f13e915a00a3c74', None)] (Background on this error at: http://sqlalche.me/e/4xp6)
Ok so in the config folder, delete the database.
OK, now it seem to works again.
Yesterday night I resarted it many time unsuccesfully…
It seemed like a nightmare!
Many thanks @DavidFW1960
Once you connect with putty how do you get the configuration file to delete data base
