I am having a strange issue…
When compiling a esphome yaml within the esphome addon and selecting manual download, I am getting a browser error. It tells me that the *.bin.part file can not be saved as the source file can not be read.
Wireless upload is working.
And when I am using the terminal within the esphome docker image and “esphome compile the.yaml” it also works and the bin file is created.
Seems to be a systemwide problem, as the problem persists no matter which yaml I am using?!
I am a little bit lost. Also tried a different browser to be sure that this is not a cache/cookie/browser related problem.
Does anyone know the problem?
Best regards and thanks in advance,
Otto
Nothing is not really correct. Nothing special, I would say:
2024-05-31 06:32:37,342 INFO 101 GET /compile (0.0.0.0) 0.45ms
2024-05-31 06:32:37,343 INFO Running command 'esphome --dashboard compile /config/esphome/klo-vorne.yaml'
2024-05-31 06:32:40,572 INFO Process exited with return code 0
2024-05-31 06:32:40,612 INFO 304 GET /downloads?configuration=klo-vorne.yaml (0.0.0.0) 0.61ms
2024-05-31 06:32:40,659 INFO 200 GET /download.bin?configuration=klo-vorne.yaml&file=firmware.bin&download=klo_vorne.bin (0.0.0.0) 2.55ms
