Hello, I recently bought a Philips Hue Gradient Lightstrip, but in HA it only shows as 1 light/color. Am I missing something?
I don’t want a hue bridge, OK?
ZHA has not as much devices supported than Zigbee2Mqtt.
ZHA is the default way using Zigbee devices in HA.
See here: Philips Hue Play Gradient Lightstrip LCX002 Zigbee compatibility
ZHA is currently not listed to be supported.
Zigbee2Mqtt is higher effort to get running because you need a Mqtt server too.
so what should I do if i have ZHA? Should I do something in YAML?
There’s already an open request for gradient support here.
You can add a thumbs up to show your support.
Thank You!
