I bought a homematic ccu3 which actually is a raspberry pi3 with a board on it which has separate power plug.
I’m changing the SD of this with a hassio one and I’m trying to install homematic ccu plugin in hassio and configure it.
Since there aren’t any examples of ccu3 I’m using this configuration from documentation:
rf_enable: true
wired_enable: false
hmip_enable: false
rf:
- type: CCU2
device: /dev/ttyAMA0
wired:
- serial: xy
key: abc
ip: 192.168.1.0
hmip:
- type: HMIP_CCU2
device: /dev/ttyUSB0
After I start it I get a lot of errors like:
2020-12-14 20:05:59,339 [ERROR] BidCosRpcDispatcher - Could not register BidCos-RF_java```
WARNING: Thread Thread[vert.x-eventloop-thread-2,5,main] has been blocked for 9135 ms, time limit is 2000
io.vertx.core.VertxException: Thread blocked
at [email protected]/jdk.internal.misc.Unsafe.park(Native Method)
at [email protected]/java.util.concurrent.locks.LockSupport.parkNanos(LockSupport.java:234)
at [email protected]/java.util.concurrent.locks.AbstractQueuedSynchronizer$ConditionObject.awaitNanos(AbstractQueuedSynchronizer.java:2123)
at [email protected]/java.util.concurrent.LinkedBlockingQueue.poll(LinkedBlockingQueue.java:458)
at app//de.eq3.ccu.virtualdevice.service.internal.rega.VirtualDeviceHandlerRega.registerCallback(VirtualDeviceHandlerRega.java:99)
at [email protected]/jdk.internal.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at [email protected]/jdk.internal.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)
at [email protected]/jdk.internal.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
at [email protected]/java.lang.reflect.Method.invoke(Method.java:566)
at app//de.eq3.cbcs.legacy.communication.rpc.internal.rpc.AnnotationAwareRpcHandler.execute(AnnotationAwareRpcHandler.java:80)
at app//de.eq3.ccu.server.internal.RpcMessageHandler.handle(RpcMessageHandler.java:70)
at app//de.eq3.ccu.server.internal.RpcMessageHandler.handle(RpcMessageHandler.java:24)
at app//io.vertx.core.eventbus.impl.HandlerRegistration.deliver(HandlerRegistration.java:212)
at app//io.vertx.core.eventbus.impl.HandlerRegistration.handle(HandlerRegistration.java:191)
at app//io.vertx.core.eventbus.impl.EventBusImpl.lambda$deliverToHandler$3(EventBusImpl.java:505)
at app//io.vertx.core.eventbus.impl.EventBusImpl$$Lambda$158/0x6e708028.handle(Unknown Source)
at app//io.vertx.core.impl.ContextImpl.lambda$wrapTask$2(ContextImpl.java:337)
at app//io.vertx.core.impl.ContextImpl$$Lambda$86/0x6e713028.run(Unknown Source)
at app//io.netty.util.concurrent.AbstractEventExecutor.safeExecute(AbstractEventExecutor.java:163)
at app//io.netty.util.concurrent.SingleThreadEventExecutor.runAllTasks(SingleThreadEventExecutor.java:403)
at app//io.netty.channel.nio.NioEventLoop.run(NioEventLoop.java:445)
at app//io.netty.util.concurrent.SingleThreadEventExecutor$5.run(SingleThreadEventExecutor.java:858)
at [email protected]/java.lang.Thread.run(Thread.java:834)
I also did the config.txt which wasn’t easy to do at all on the boot partition
dtoverlay=pi3-miniuart-bt
The hardware output is this:
serial:
- /dev/ttyAMA0
- /dev/ttyS0
input: []
disk:
- /dev/mmcblk0
- /dev/mmcblk0p1
- /dev/mmcblk0p2
- /dev/mmcblk0p3
- /dev/mmcblk0p4
- /dev/mmcblk0p5
- /dev/mmcblk0p6
- /dev/mmcblk0p7
- /dev/mmcblk0p8
gpio:
- gpio18
- gpiochip100
- gpiochip0
- gpiochip504
usb:
- /dev/bus/usb/001/001
- /dev/bus/usb/001/002
- /dev/bus/usb/001/003
audio:
'0':
name: bcm2835_alsa - bcm2835 ALSA
type: ALSA
devices:
- chan_id: '0'
chan_type: digital audio playback
- chan_id: '1'
- chan_id: '2'
anyone managed to do this successfully?
Basically ccu3 is just a raspberry pi 3b+ with a board on it… photo attached.
