I am seeing this warning when running the Check Home Assistant configuration 2.2 add for Hassio.
WARNING: You are using pip version 19.1.1, however version 19.2.3 is available.
You should consider upgrading via the 'pip install --upgrade pip' command.
When i went to the console using VScode i see this error when running this command
File "/usr/local/bin/pip", line 6, in <module>
from pip._internal import main
File "/usr/local/lib/python3.6/dist-packages/pip/_internal/__init__.py", line 40, in <module>
from pip._internal.cli.autocompletion import autocomplete
File "/usr/local/lib/python3.6/dist-packages/pip/_internal/cli/autocompletion.py", line 8, in <module>
from pip._internal.cli.main_parser import create_main_parser
File "/usr/local/lib/python3.6/dist-packages/pip/_internal/cli/main_parser.py", line 7, in <module>
from pip._internal.cli import cmdoptions
File "/usr/local/lib/python3.6/dist-packages/pip/_internal/cli/cmdoptions.py", line 15, in <module>
from distutils.util import strtobool
ModuleNotFoundError: No module named 'distutils.util'
How do i update pip?
