Hassio Ingress: header for user name exist?
Hello everyone!
I’m working on a new add-on for hassio, to integrate this -> https://filebrowser.xyz/ to our home system.
It mount NFS disk inside the add-on and expose a cloud-like interface for users.
It works almost perfectly, but I would like to integrate automatic login, Because filebrowser support an auth method which consists of a header with the username.
Does currently Ingress send some kind of http header with the current user name?
Thanks,
Alessandro
Hi Rihan,
Were you able to find an answer to your question? For a different add-on (radicale, a carddav server) I’d like to do the same thing.
Hi Zeehio,
no, Nothing. In the end, all I could do was to use the standard login form of the application.
I’m sorry I can’t help you
@Rihan @zeehio did you find a solution in the meantime?
The solution I found is able to use home-assistant credentials but it does not use ingress:
  1. The app I wanted to create a home-assistant addon for (radicale) supported this “authentication-based header” described also on the first post in this thread.
  2. I created an add-on that runs my app under the container’s localhost interface (in my case it runs on port 5232). This is only directly accessible from within the container.
  3. The add-on container also runs an nginx server, which is the main endpoint of the add-on. The add-on exposes this nginx server. This nginx server presents a basic-auth form when it receives a request. It then uses the home asisstant supervisor API to validate the credentials and, if the validation succeeds, nginx sets in the received request a header of my choice (X-Remote-User) with the validated user name. The request is then forwarded to the container’s localhost:5232 so the app receives the request with the username and can provide a response.
Check my nginx configuration, yaml settings and Docker file at:
Cool :sunglasses:
I actually considered doing the same. Seems like you saved me a lot of time :slight_smile:
