root@ad-Aspire-5741ZG:/home/ad# curl -sL “https://raw.githubusercontent.com/home-assistant/supervised-installer/master/installer.sh” | bash -s
[warn]
[warn] If you want more control over your own system, run
[warn] Home Assistant as a VM or run Home Assistant Core
[warn] via a Docker container.
[warn]
[warn] If you want to abort, hit ctrl+c within 10 seconds…
[warn]
[warn] ModemManager service is enabled. This might cause issue when using serial devices.
[info] Creating default docker deamon configuration /etc/docker/daemon.json
[info] Restarting docker service
[info] Creating NetworkManager configuration
[info] Restarting NetworkManager
[info] Install supervisor Docker container
Error response from daemon: Get https:/registry-1.docker.io/v2/: dial tcp: lookup registry-1.docker.io: Temporary failure in name resolution
