HASSIO internal Docker dns routing to wrong DNS when installing Add-ons
I just recently after one of the new updates could no longer update some of my plug-ins. I noticed the log kept giving me a “No Route to Host”
I found items like Community Add-Ons like ESPHome installs with no issue. I assume its not a docker container using the internal docker container dns of 172.30.32.1.
However all fails and reference “https://ghcr.io/v2/”: dial tcp 192.30.255.165 :443: connect: no route to host"
EDIT: FIXED THIS ISSUE. I had the VLAN20 set to 192.168.20.40/8. Needed a subnet mask of 24 and all works great now.
From terminal plugin in HA I can’t ~$ ping 192.30.255.165
Found the error when running terminal in HA
~$ traceroute 192.30.255.165
traceroute to 192.30.255.165 (192.30.255.165), 30 hops max, 46 byte packets
** 1 d7b954-nodered.local.hass.io (172.30.32.1) 0.004 ms 0.003 ms 0.001 ms**
** 2 192.168.20.40 (192.168.20.40) 3081.201 ms !H 3070.861 ms !H 3071.967 ms !H**
192.168.20.40 is my actual VLAN IP of the Homeassitant. Anyone know how to get this directed to the correct dns of 192.168.20.1?
In my network setting under supervisor host I have (2) IP’s
eth0 - DHCP (Its static on my router 192.168.1.40/24)
eth0.20 - Static (IP:192.168.20.40/8, Gateway:192.168.20.1, DNS:192.168.20.1)
This should be referencing 192.168.1.1 or 192.168.20.1
Changed subnet mask for VLAN to from /8 to /24 and all works great now.
