Hassio is broken?
Hey guys,
I recently updated to 100.3 and since then it’s broken, like it won’t update anymore.
19-11-13 21:24:39 WARNING (MainThread) [hassio.homeassistant] Don't wait anymore of Home Assistant startup!
19-11-13 21:24:39 CRITICAL (MainThread) [hassio.homeassistant] HomeAssistant update fails -> rollback!
19-11-13 21:24:39 INFO (MainThread) [hassio.homeassistant] Update Home Assistant to version 0.100.3
19-11-13 21:24:39 INFO (SyncWorker_4) [hassio.docker.interface] Update image homeassistant/qemux86-64-homeassistant:0.101.3 to homeassistant/qemux86-64-homeassistant:0.100.3
19-11-13 21:24:39 INFO (SyncWorker_4) [hassio.docker.interface] Pull image homeassistant/qemux86-64-homeassistant tag 0.100.3.
19-11-13 21:24:39 INFO (MainThread) [hassio.api.proxy] Home Assistant WebSocket API request initialize
19-11-13 21:24:39 INFO (MainThread) [hassio.api.proxy] WebSocket access from a0d7b954_nodered
19-11-13 21:24:39 ERROR (MainThread) [hassio.api.proxy] Client error on WebSocket API Cannot connect to host 172.30.32.1:8123 ssl:False [Connection refused].
19-11-13 21:24:40 INFO (SyncWorker_4) [hassio.docker.interface] Stop homeassistant application
19-11-13 21:24:44 INFO (MainThread) [hassio.api.proxy] Home Assistant WebSocket API request initialize
19-11-13 21:24:44 INFO (MainThread) [hassio.api.proxy] WebSocket access from a0d7b954_nodered
19-11-13 21:24:44 ERROR (MainThread) [hassio.api.proxy] Client error on WebSocket API Cannot connect to host 172.30.32.1:8123 ssl:False [Connection refused].
19-11-13 21:24:46 INFO (SyncWorker_4) [hassio.docker.interface] Clean homeassistant application
19-11-13 21:24:46 INFO (SyncWorker_11) [hassio.docker.homeassistant] Start homeassistant homeassistant/qemux86-64-homeassistant with version 0.100.3
19-11-13 21:24:49 INFO (MainThread) [hassio.api.proxy] Home Assistant WebSocket API request initialize
19-11-13 21:24:49 INFO (MainThread) [hassio.api.proxy] WebSocket access from a0d7b954_nodered
19-11-13 21:24:49 ERROR (MainThread) [hassio.api.proxy] Client error on WebSocket API Cannot connect to host 172.30.32.1:8123 ssl:False [Connection refused].
19-11-13 21:24:51 INFO (MainThread) [hassio.homeassistant] Home Assistant pip installation in progress
19-11-13 21:24:54 INFO (MainThread) [hassio.api.proxy] Home Assistant WebSocket API request initialize
19-11-13 21:24:54 INFO (MainThread) [hassio.api.proxy] WebSocket access from a0d7b954_nodered
19-11-13 21:24:54 ERROR (MainThread) [hassio.api.proxy] Client error on WebSocket API Cannot connect to host 172.30.32.1:8123 ssl:False [Connection refused].
19-11-13 21:24:59 INFO (MainThread) [hassio.api.proxy] Home Assistant WebSocket API request initialize
19-11-13 21:24:59 INFO (MainThread) [hassio.api.proxy] WebSocket access from a0d7b954_nodered
19-11-13 21:24:59 ERROR (MainThread) [hassio.api.proxy] Client error on WebSocket API Cannot connect to host 172.30.32.1:8123 ssl:False [Connection refused].
19-11-13 21:25:04 INFO (MainThread) [hassio.api.proxy] Home Assistant WebSocket API request initialize
19-11-13 21:25:04 INFO (MainThread) [hassio.api.proxy] WebSocket access from a0d7b954_nodered
19-11-13 21:25:04 ERROR (MainThread) [hassio.api.proxy] Client error on WebSocket API Cannot connect to host 172.30.32.1:8123 ssl:False [Connection refused].
19-11-13 21:25:09 INFO (MainThread) [hassio.api.proxy] Home Assistant WebSocket API request initialize
19-11-13 21:25:09 INFO (MainThread) [hassio.api.proxy] WebSocket access from a0d7b954_nodered
19-11-13 21:25:09 ERROR (MainThread) [hassio.api.proxy] Client error on WebSocket API Cannot connect to host 172.30.32.1:8123 ssl:False [Connection refused].
19-11-13 21:25:14 INFO (MainThread) [hassio.api.proxy] Home Assistant WebSocket API request initialize
19-11-13 21:25:14 INFO (MainThread) [hassio.api.proxy] WebSocket access from a0d7b954_nodered
19-11-13 21:25:14 ERROR (MainThread) [hassio.api.proxy] Client error on WebSocket API Cannot connect to host 172.30.32.1:8123 ssl:False [Connection refused].
19-11-13 21:25:16 INFO (MainThread) [hassio.homeassistant] Home Assistant pip installation done
19-11-13 21:25:19 INFO (MainThread) [hassio.api.proxy] Home Assistant WebSocket API request initialize
19-11-13 21:25:19 INFO (MainThread) [hassio.api.proxy] WebSocket access from a0d7b954_nodered
19-11-13 21:25:19 ERROR (MainThread) [hassio.api.proxy] Client error on WebSocket API Cannot connect to host 172.30.32.1:8123 ssl:False [Connection refused].
19-11-13 21:25:24 INFO (MainThread) [hassio.api.proxy] Home Assistant WebSocket API request initialize
19-11-13 21:25:24 INFO (MainThread) [hassio.api.proxy] WebSocket access from a0d7b954_nodered
19-11-13 21:25:24 ERROR (MainThread) [hassio.api.proxy] Client error on WebSocket API Cannot connect to host 172.30.32.1:8123 ssl:False [Connection refused].
19-11-13 21:25:29 INFO (MainThread) [hassio.api.proxy] Home Assistant WebSocket API request initialize
19-11-13 21:25:29 INFO (MainThread) [hassio.api.proxy] WebSocket access from a0d7b954_nodered
19-11-13 21:25:29 INFO (MainThread) [hassio.homeassistant] Updated Home Assistant API token
19-11-13 21:25:29 INFO (MainThread) [hassio.api.proxy] Home Assistant WebSocket API request running
19-11-13 21:25:31 INFO (MainThread) [hassio.homeassistant] Detect a running Home Assistant instance
19-11-13 21:25:31 INFO (MainThread) [hassio.homeassistant] Successful run Home Assistant 0.100.3
19-11-13 21:25:31 INFO (SyncWorker_14) [hassio.docker.interface] Cleanup images: ['homeassistant/qemux86-64-homeassistant:0.101.3']
I have no idea where to look; I have enough disk space, I have network connection and internet connection. I am running hassio inside a virtual machine based on: https://github.com/whiskerz007/proxmox_hassos_install.
It was able to update for like always but since update 0.100.3 it won’t update anymore.
Anyone a idea?
Look in your logs.
Consult this: How to help us help you - or How to ask a good question
Solved!
Still had api_password inside the config.yaml.
Removing it allowed update
