Hi all
So I don’t know any more, couple of weeks ago wife mentioned to me Hassio is dead, (I work remotely and commute so can only fix when home) so on the last trip past weekend I checked and found/assumed memory card is the problem,
(My deployment is Hassio as a docker image on a Raspberry Pi 3B).
SO I rebuild it, well the rebuild was more a restore of a backup image I created of my SD card after the last build, initially all that it did was start the supervisor servers and the dns server, and nothing more, after doing some rerunning of the build commands, it all came back, and was running stable for the last 4 days that I was home, last night, log in remotely via the VPN and guess what, all dead again, well HASSIO is dead, not the pi, I can log in, and I can again only see the supervisor servers and dns.
I’ attaching output of docker logs below, whats wrong, where do I start fixing.
please help.
pi@hassio:~ $ docker ps
CONTAINER ID IMAGE COMMAND CREATED STATUS PORTS NAMES
444803c377ae homeassistant/armv7-hassio-dns:1 "coredns -conf /conf…" 12 minutes ago Up 12 minutes hassio_dns
53bbedb328e5 homeassistant/armv7-hassio-supervisor "/bin/entry.sh pytho…" 38 minutes ago Up 12 minutes hassio_supervisor
pi@hassio:~ $ docker logs --details 53bbedb328e5
20-02-18 16:08:26 INFO (MainThread) [__main__] Initialize Hass.io setup
20-02-18 16:08:27 INFO (MainThread) [hassio.bootstrap] Create Home Assistant configuration folder /data/homeassistant
20-02-18 16:08:27 INFO (MainThread) [hassio.bootstrap] Create Hass.io SSL/TLS folder /data/ssl
20-02-18 16:08:27 INFO (MainThread) [hassio.bootstrap] Create Hass.io Add-on data folder /data/addons/data
20-02-18 16:08:27 INFO (MainThread) [hassio.bootstrap] Create Hass.io Add-on local repository folder /data/addons/local
20-02-18 16:08:27 INFO (MainThread) [hassio.bootstrap] Create Hass.io Add-on git repositories folder /data/addons/git
20-02-18 16:08:27 INFO (MainThread) [hassio.bootstrap] Create Hass.io temp folder /data/tmp
20-02-18 16:08:27 INFO (MainThread) [hassio.bootstrap] Create Hass.io backup folder /data/backup
20-02-18 16:08:27 INFO (MainThread) [hassio.bootstrap] Create Hass.io share folder /data/share
20-02-18 16:08:27 INFO (MainThread) [hassio.bootstrap] Create Hass.io DNS folder /data/dns
20-02-18 16:08:27 INFO (SyncWorker_0) [hassio.docker.supervisor] Attach to Supervisor homeassistant/armv7-hassio-supervisor with version 201
20-02-18 16:08:27 INFO (SyncWorker_0) [hassio.docker.supervisor] Connect Supervisor to Hass.io Network
20-02-18 16:08:29 INFO (SyncWorker_0) [hassio.docker.interface] Cleanup images: ['homeassistant/armv7-hassio-supervisor:200']
20-02-18 16:08:29 INFO (MainThread) [__main__] Setup HassIO
20-02-18 16:08:30 INFO (MainThread) [hassio.utils.gdbus] Connect to dbus: org.freedesktop.systemd1 - /org/freedesktop/systemd1
20-02-18 16:08:30 INFO (MainThread) [hassio.utils.gdbus] Connect to dbus: org.freedesktop.hostname1 - /org/freedesktop/hostname1
20-02-18 16:08:30 WARNING (MainThread) [hassio.dbus.rauc] Host has no rauc support. OTA updates have been disabled.
20-02-18 16:08:30 INFO (MainThread) [hassio.utils.gdbus] Connect to dbus: org.freedesktop.NetworkManager - /org/freedesktop/NetworkManager/DnsManager
20-02-18 16:08:30 INFO (MainThread) [hassio.host.info] Update local host information
20-02-18 16:08:30 INFO (MainThread) [hassio.utils.gdbus] Call org.freedesktop.DBus.Properties.GetAll on /org/freedesktop/hostname1
20-02-18 16:08:30 INFO (MainThread) [hassio.host.services] Update service information
20-02-18 16:08:30 INFO (MainThread) [hassio.utils.gdbus] Call org.freedesktop.systemd1.Manager.ListUnits on /org/freedesktop/systemd1
20-02-18 16:08:31 INFO (MainThread) [hassio.host.network] Update local network DNS information
20-02-18 16:08:31 INFO (MainThread) [hassio.utils.gdbus] Call org.freedesktop.DBus.Properties.GetAll on /org/freedesktop/NetworkManager/DnsManager
20-02-18 16:08:31 INFO (MainThread) [hassio.host.apparmor] Load AppArmor Profiles: {'hassio-supervisor'}
20-02-18 16:08:31 INFO (MainThread) [hassio.host.services] Reload local service hassio-apparmor.service
20-02-18 16:08:31 INFO (MainThread) [hassio.utils.gdbus] Call org.freedesktop.systemd1.Manager.ReloadOrRestartUnit on /org/freedesktop/systemd1
20-02-18 16:08:31 INFO (SyncWorker_0) [hassio.docker.interface] Attach to homeassistant/armv7-hassio-dns with version 1
20-02-18 16:08:31 INFO (MainThread) [hassio.misc.forwarder] Start DNS port forwarding to 172.30.32.3
20-02-18 16:08:31 INFO (SyncWorker_3) [hassio.docker.interface] Restart homeassistant/armv7-hassio-dns
20-02-18 16:08:36 INFO (MainThread) [hassio.homeassistant] No Home Assistant Docker image homeassistant/intel-nuc-homeassistant found.
20-02-18 16:08:36 INFO (MainThread) [hassio.homeassistant] Setup HomeAssistant landingpage
20-02-18 16:08:36 INFO (SyncWorker_1) [hassio.docker.interface] Pull image homeassistant/intel-nuc-homeassistant tag landingpage.
20-02-18 16:08:55 INFO (MainThread) [hassio.homeassistant] Start HomeAssistant landingpage
20-02-18 16:09:00 INFO (MainThread) [hassio.homeassistant] Detect a running Home Assistant instance
20-02-18 16:09:00 INFO (MainThread) [hassio.store.git] Clone add-on https://github.com/hassio-addons/repository repository
20-02-18 16:09:00 INFO (MainThread) [hassio.store.git] Clone add-on https://github.com/home-assistant/hassio-addonsrepository
20-02-18 16:09:08 INFO (MainThread) [hassio.store] Load add-ons from store: 63 all - 63 new - 0 remove
20-02-18 16:09:08 INFO (MainThread) [hassio.addons] Found 0 installed add-ons
20-02-18 16:09:08 INFO (MainThread) [hassio.updater] Fetch update data from https://version.home-assistant.io/stable.json
20-02-18 16:09:08 INFO (MainThread) [hassio.snapshots] Found 0 snapshot files
20-02-18 16:09:08 INFO (MainThread) [hassio.discovery] Load 0 messages
20-02-18 16:09:08 INFO (MainThread) [hassio.ingress] Load 0 ingress session
20-02-18 16:09:08 INFO (MainThread) [hassio.secrets] Load Home Assistant secrets: 0
20-02-18 16:09:08 INFO (MainThread) [__main__] Run Hass.io
20-02-18 16:09:08 INFO (MainThread) [hassio.api] Start API on 172.30.32.2
20-02-18 16:09:08 INFO (MainThread) [hassio.addons] Phase 'initialize' start 0 add-ons
20-02-18 16:09:08 INFO (MainThread) [hassio.addons] Phase 'system' start 0 add-ons
20-02-18 16:09:08 INFO (MainThread) [hassio.addons] Phase 'services' start 0 add-ons
20-02-18 16:09:08 INFO (MainThread) [hassio.core] Skip start of Home Assistant
20-02-18 16:09:08 INFO (MainThread) [hassio.addons] Phase 'application' start 0 add-ons
20-02-18 16:09:08 INFO (MainThread) [hassio.tasks] All core tasks are scheduled
20-02-18 16:09:08 INFO (MainThread) [hassio.core] Hass.io is up and running
20-02-18 16:09:08 INFO (MainThread) [hassio.homeassistant] Setup Home Assistant
20-02-18 16:09:08 INFO (SyncWorker_9) [hassio.docker.interface] Update image homeassistant/intel-nuc-homeassistant:landingpage to homeassistant/intel-nuc-homeassistant:0.105.5
20-02-18 16:09:08 INFO (SyncWorker_9) [hassio.docker.interface] Pull image homeassistant/intel-nuc-homeassistant tag 0.105.5.
20-02-18 16:09:10 INFO (MainThread) [hassio.api.proxy] Home Assistant WebSocket API request initialize
20-02-18 16:09:10 WARNING (MainThread) [hassio.api.proxy] Unauthorized WebSocket access!
20-02-18 16:10:57 WARNING (MainThread) [hassio.api.proxy] Unknown Home Assistant API access!
20-02-18 16:15:03 WARNING (MainThread) [hassio.api.proxy] Unknown Home Assistant API access!
20-02-18 16:15:54 INFO (SyncWorker_9) [hassio.docker.interface] Stop homeassistant application
20-02-18 16:16:07 INFO (SyncWorker_9) [hassio.docker.interface] Clean homeassistant application
20-02-18 16:16:08 INFO (MainThread) [hassio.homeassistant] Home Assistant docker now installed
20-02-18 16:16:08 INFO (MainThread) [hassio.homeassistant] Start Home Assistant
20-02-18 16:16:09 INFO (SyncWorker_2) [hassio.docker.homeassistant] Start homeassistant homeassistant/intel-nuc-homeassistant with version 0.105.5
20-02-18 16:16:14 ERROR (MainThread) [hassio.homeassistant] Home Assistant has crashed!
20-02-18 16:16:14 ERROR (MainThread) [hassio.homeassistant] Can't start Home Assistant!
20-02-18 16:16:14 INFO (SyncWorker_13) [hassio.docker.interface] Cleanup images: ['homeassistant/intel-nuc-homeassistant:landingpage']
20-02-18 16:20:08 WARNING (MainThread) [hassio.api.proxy] Unknown Home Assistant API access!
20-02-18 16:25:12 ERROR (MainThread) [hassio.api.security] Invalid token for access /auth
20-02-18 16:25:13 WARNING (MainThread) [hassio.api.proxy] Unknown Home Assistant API access!
20-02-18 16:25:15 ERROR (MainThread) [hassio.api.security] Invalid token for access /auth
20-02-18 16:25:23 ERROR (MainThread) [hassio.api.security] Invalid token for access /auth
20-02-18 16:26:28 ERROR (MainThread) [hassio.api.security] Invalid token for access /auth
20-02-18 16:26:32 ERROR (MainThread) [hassio.api.security] Invalid token for access /auth
20-02-18 16:26:35 ERROR (MainThread) [hassio.api.security] Invalid token for access /auth
20-02-18 16:26:40 ERROR (MainThread) [hassio.api.security] Invalid token for access /auth
20-02-18 16:26:54 ERROR (MainThread) [hassio.api.security] Invalid token for access /auth
20-02-18 16:30:18 WARNING (MainThread) [hassio.api.proxy] Unknown Home Assistant API access!
20-02-18 16:32:59 INFO (MainThread) [__main__] Stopping Hass.io
20-02-18 16:32:59 INFO (MainThread) [hassio.api] Stop API on 172.30.32.2
20-02-18 16:32:59 INFO (MainThread) [hassio.misc.forwarder] Stop DNS forwarding
20-02-18 16:32:59 INFO (MainThread) [hassio.core] Hass.io is down
20-02-18 16:32:59 INFO (MainThread) [__main__] Close Hass.io
20-02-18 16:33:42 INFO (MainThread) [__main__] Initialize Hass.io setup
20-02-18 16:33:43 INFO (SyncWorker_0) [hassio.docker.supervisor] Attach to Supervisor homeassistant/armv7-hassio-supervisor with version 201
20-02-18 16:33:43 INFO (MainThread) [__main__] Setup HassIO
20-02-18 16:33:43 INFO (MainThread) [hassio.utils.gdbus] Connect to dbus: org.freedesktop.systemd1 - /org/freedesktop/systemd1
20-02-18 16:33:43 INFO (MainThread) [hassio.utils.gdbus] Connect to dbus: org.freedesktop.hostname1 - /org/freedesktop/hostname1
20-02-18 16:33:43 WARNING (MainThread) [hassio.dbus.rauc] Host has no rauc support. OTA updates have been disabled.
20-02-18 16:33:43 INFO (MainThread) [hassio.utils.gdbus] Connect to dbus: org.freedesktop.NetworkManager - /org/freedesktop/NetworkManager/DnsManager
20-02-18 16:33:43 INFO (MainThread) [hassio.host.info] Update local host information
20-02-18 16:33:43 INFO (MainThread) [hassio.utils.gdbus] Call org.freedesktop.DBus.Properties.GetAll on /org/freedesktop/hostname1
20-02-18 16:33:43 INFO (MainThread) [hassio.host.services] Update service information
20-02-18 16:33:43 INFO (MainThread) [hassio.utils.gdbus] Call org.freedesktop.systemd1.Manager.ListUnits on /org/freedesktop/systemd1
20-02-18 16:33:43 INFO (MainThread) [hassio.host.network] Update local network DNS information
20-02-18 16:33:43 INFO (MainThread) [hassio.utils.gdbus] Call org.freedesktop.DBus.Properties.GetAll on /org/freedesktop/NetworkManager/DnsManager
20-02-18 16:33:43 INFO (MainThread) [hassio.host.apparmor] Load AppArmor Profiles: {'hassio-supervisor'}
20-02-18 16:33:43 INFO (MainThread) [hassio.host.services] Reload local service hassio-apparmor.service
20-02-18 16:33:43 INFO (MainThread) [hassio.utils.gdbus] Call org.freedesktop.systemd1.Manager.ReloadOrRestartUnit on /org/freedesktop/systemd1
20-02-18 16:33:44 INFO (SyncWorker_1) [hassio.docker.interface] Attach to homeassistant/armv7-hassio-dns with version 1
20-02-18 16:33:44 INFO (MainThread) [hassio.misc.forwarder] Start DNS port forwarding to 172.30.32.3
20-02-18 16:33:44 INFO (MainThread) [hassio.dns] Start CoreDNS plugin
20-02-18 16:33:44 INFO (SyncWorker_1) [hassio.docker.interface] Clean hassio_dns application
20-02-18 16:33:54 INFO (SyncWorker_1) [hassio.docker.dns] Start DNS homeassistant/armv7-hassio-dns with version 1 - 172.30.32.3
20-02-18 16:33:54 INFO (SyncWorker_3) [hassio.docker.interface] Attach to homeassistant/intel-nuc-homeassistant with version 0.105.5
20-02-18 16:33:55 INFO (MainThread) [hassio.store.git] Load add-on /data/addons/core repository
20-02-18 16:33:55 INFO (MainThread) [hassio.store.git] Load add-on /data/addons/git/a0d7b954 repository
20-02-18 16:33:56 INFO (MainThread) [hassio.store] Load add-ons from store: 63 all - 63 new - 0 remove
20-02-18 16:33:56 INFO (MainThread) [hassio.addons] Found 0 installed add-ons
20-02-18 16:33:56 INFO (MainThread) [hassio.updater] Fetch update data from https://version.home-assistant.io/stable.json
20-02-18 16:33:56 INFO (MainThread) [hassio.snapshots] Found 0 snapshot files
20-02-18 16:33:56 INFO (MainThread) [hassio.discovery] Load 0 messages
20-02-18 16:33:56 INFO (MainThread) [hassio.ingress] Load 0 ingress session
20-02-18 16:33:56 INFO (MainThread) [hassio.secrets] Load Home Assistant secrets: 0
20-02-18 16:33:56 INFO (MainThread) [__main__] Run Hass.io
20-02-18 16:33:56 INFO (MainThread) [hassio.api] Start API on 172.30.32.2
20-02-18 16:33:56 INFO (MainThread) [hassio.addons] Phase 'initialize' start 0 add-ons
20-02-18 16:33:56 INFO (MainThread) [hassio.addons] Phase 'system' start 0 add-ons
20-02-18 16:33:56 INFO (MainThread) [hassio.addons] Phase 'services' start 0 add-ons
20-02-18 16:33:56 INFO (SyncWorker_1) [hassio.docker.interface] Start homeassistant/intel-nuc-homeassistant
20-02-18 16:34:02 ERROR (MainThread) [hassio.homeassistant] Home Assistant has crashed!
20-02-18 16:34:02 INFO (MainThread) [hassio.addons] Phase 'application' start 0 add-ons
20-02-18 16:34:02 INFO (MainThread) [hassio.tasks] All core tasks are scheduled
20-02-18 16:34:02 INFO (MainThread) [hassio.core] Hass.io is up and running
pi@hassio:~ $
pi@hassio:~ $ docker logs --details 444803c377ae
.:53
2020-02-18T18:33:55.805+02:00 [INFO] CoreDNS-1.6.1
2020-02-18T18:33:55.818+02:00 [INFO] linux/arm, go1.12.7, 1fda570
CoreDNS-1.6.1
