Starting on Saturday, HassIO on my rPi3 keeps rebooting about every 15 minutes or so. I can’t figure out what keeps triggering it. It’s very frustrating, as it keeps turning off all my lights, then triggering my automation to turn on the lights when I get home after dark.
Any ideas as to the culprit here?
2018-10-15 11:28:07 WARNING (Recorder) [homeassistant.components.recorder] Ended unfinished session (id=274 from 2018-10-15 15:16:03.094331)
2018-10-15 11:28:12 WARNING (MainThread) [homeassistant.setup] Setup of recorder is taking over 10 seconds.
2018-10-15 11:28:25 WARNING (MainThread) [homeassistant.setup] Setup of input_number is taking over 10 seconds.
2018-10-15 11:28:34 WARNING (MainThread) [homeassistant.components.sensor] Setup of platform mqtt_room is taking over 10 seconds.
2018-10-15 11:28:34 WARNING (MainThread) [homeassistant.components.sensor] Setup of platform mqtt is taking over 10 seconds.
2018-10-15 11:28:34 WARNING (MainThread) [homeassistant.components.media_player] Setup of platform gpmdp is taking over 10 seconds.
2018-10-15 11:28:42 WARNING (MainThread) [homeassistant.components.light] Setup of platform mqtt is taking over 10 seconds.
2018-10-15 11:28:42 WARNING (MainThread) [homeassistant.components.light] Setup of platform mqtt_json is taking over 10 seconds.
2018-10-15 11:28:43 WARNING (MainThread) [homeassistant.components.switch] Setup of platform mqtt is taking over 10 seconds.
2018-10-15 11:29:19 ERROR (MainThread) [homeassistant.core] Error doing job: Task exception was never retrieved
File "/usr/local/lib/python3.6/site-packages/urllib3/response.py", line 331, in _error_catcher
yield
File "/usr/local/lib/python3.6/site-packages/urllib3/response.py", line 413, in read
data = self._fp.read(amt)
File "/usr/local/lib/python3.6/http/client.py", line 449, in read
n = self.readinto(b)
File "/usr/local/lib/python3.6/http/client.py", line 493, in readinto
n = self.fp.readinto(b)
File "/usr/local/lib/python3.6/socket.py", line 586, in readinto
return self._sock.recv_into(b)
socket.timeout: timed out
File "/usr/local/lib/python3.6/site-packages/requests/models.py", line 749, in generate
for chunk in self.raw.stream(chunk_size, decode_content=True):
File "/usr/local/lib/python3.6/site-packages/urllib3/response.py", line 465, in stream
data = self.read(amt=amt, decode_content=decode_content)
File "/usr/local/lib/python3.6/site-packages/urllib3/response.py", line 430, in read
raise IncompleteRead(self._fp_bytes_read, self.length_remaining)
File "/usr/local/lib/python3.6/contextlib.py", line 99, in __exit__
self.gen.throw(type, value, traceback)
File "/usr/local/lib/python3.6/site-packages/urllib3/response.py", line 336, in _error_catcher
raise ReadTimeoutError(self._pool, None, 'Read timed out.')
urllib3.exceptions.ReadTimeoutError: HTTPConnectionPool(host='192.168.1.1', port=80): Read timed out.
File "/usr/local/lib/python3.6/site-packages/homeassistant/components/device_tracker/__init__.py", line 698, in async_device_tracker_scan
host_name = await scanner.async_get_device_name(mac)
File "/usr/local/lib/python3.6/concurrent/futures/thread.py", line 56, in run
File "/usr/local/lib/python3.6/site-packages/homeassistant/components/device_tracker/ddwrt.py", line 67, in get_device_name
data = self.get_ddwrt_data(url)
File "/usr/local/lib/python3.6/site-packages/homeassistant/components/device_tracker/ddwrt.py", line 128, in get_ddwrt_data
url, auth=(self.username, self.password), timeout=4)
File "/usr/local/lib/python3.6/site-packages/requests/api.py", line 72, in get
return request('get', url, params=params, **kwargs)
File "/usr/local/lib/python3.6/site-packages/requests/api.py", line 58, in request
return session.request(method=method, url=url, **kwargs)
File "/usr/local/lib/python3.6/site-packages/requests/sessions.py", line 512, in request
resp = self.send(prep, **send_kwargs)
File "/usr/local/lib/python3.6/site-packages/requests/sessions.py", line 662, in send
r.content
File "/usr/local/lib/python3.6/site-packages/requests/models.py", line 827, in content
self._content = b''.join(self.iter_content(CONTENT_CHUNK_SIZE)) or b''
File "/usr/local/lib/python3.6/site-packages/requests/models.py", line 756, in generate
raise ConnectionError(e)
requests.exceptions.ConnectionError: HTTPConnectionPool(host='192.168.1.1', port=80): Read timed out.
2018-10-15 11:29:28 WARNING (MainThread) [homeassistant.components.sensor] Updating rest sensor took longer than the scheduled update interval 0:00:05
2018-10-15 11:29:30 ERROR (MainThread) [homeassistant.core] Timer got out of sync. Resetting
2018-10-15 11:29:30 WARNING (MainThread) [homeassistant.helpers.entity] Update of sensor.miflora_a_light_intensity is taking over 10 seconds
2018-10-15 11:29:30 WARNING (MainThread) [homeassistant.helpers.entity] Update of sensor.miflora_a_moisture is taking over 10 seconds
2018-10-15 11:29:30 WARNING (MainThread) [homeassistant.helpers.entity] Update of sensor.miflora_a_conductivity is taking over 10 seconds
2018-10-15 11:29:30 WARNING (MainThread) [homeassistant.helpers.entity] Update of sensor.miflora_a_temperature is taking over 10 seconds
2018-10-15 11:29:30 WARNING (MainThread) [homeassistant.helpers.entity] Update of sensor.miflora_b_temperature is taking over 10 seconds
2018-10-15 11:29:32 WARNING (MainThread) [homeassistant.helpers.entity] Update of sensor.miflora_b_light_intensity is taking over 10 seconds
2018-10-15 11:29:32 WARNING (MainThread) [homeassistant.helpers.entity] Update of sensor.miflora_b_moisture is taking over 10 seconds
2018-10-15 11:29:32 WARNING (MainThread) [homeassistant.helpers.entity] Update of sensor.miflora_b_conductivity is taking over 10 seconds
2018-10-15 11:29:32 WARNING (MainThread) [homeassistant.helpers.entity] Update of sensor.miflora_c_temperature is taking over 10 seconds
2018-10-15 11:29:32 WARNING (MainThread) [homeassistant.helpers.entity] Update of sensor.miflora_c_light_intensity is taking over 10 seconds
2018-10-15 11:29:32 WARNING (MainThread) [homeassistant.helpers.entity] Update of sensor.miflora_c_moisture is taking over 10 seconds
2018-10-15 11:29:32 WARNING (MainThread) [homeassistant.helpers.entity] Update of sensor.miflora_c_conductivity is taking over 10 seconds
2018-10-15 11:29:32 WARNING (MainThread) [homeassistant.helpers.entity] Update of sensor.miflora_c_battery is taking over 10 seconds
2018-10-15 11:29:32 WARNING (MainThread) [homeassistant.helpers.entity] Update of sensor.miflora_d_conductivity is taking over 10 seconds
2018-10-15 11:29:32 WARNING (MainThread) [homeassistant.helpers.entity] Update of sensor.miflora_d_battery is taking over 10 seconds
2018-10-15 11:29:32 WARNING (MainThread) [homeassistant.helpers.entity] Update of sensor.miflora_d_temperature is taking over 10 seconds
2018-10-15 11:29:32 WARNING (MainThread) [homeassistant.helpers.entity] Update of sensor.miflora_d_light_intensity is taking over 10 seconds
2018-10-15 11:29:32 WARNING (MainThread) [homeassistant.helpers.entity] Update of sensor.miflora_d_moisture is taking over 10 seconds
2018-10-15 11:29:32 ERROR (MainThread) [homeassistant.core] Timer got out of sync. Resetting
2018-10-15 11:29:33 WARNING (MainThread) [homeassistant.components.media_player] Updating mpd media_player took longer than the scheduled update interval 0:00:10
2018-10-15 11:29:33 ERROR (MainThread) [homeassistant.core] Error doing job: Task exception was never retrieved
yield
r.content
2018-10-15 11:29:33 WARNING (MainThread) [homeassistant.components.sensor] Updating rest sensor took longer than the scheduled update interval 0:00:05
2018-10-15 11:29:41 ERROR (MainThread) [homeassistant.core] Timer got out of sync. Resetting
2018-10-15 11:29:44 ERROR (MainThread) [homeassistant.core] Timer got out of sync. Resetting
2018-10-15 11:29:47 ERROR (MainThread) [homeassistant.core] Error doing job: Task exception was never retrieved
yield
r.content
2018-10-15 11:29:48 ERROR (MainThread) [homeassistant.core] Timer got out of sync. Resetting
2018-10-15 11:29:49 WARNING (MainThread) [homeassistant.components.sensor] Updating rest sensor took longer than the scheduled update interval 0:00:05
2018-10-15 11:29:54 WARNING (MainThread) [homeassistant.components.sensor] Updating rest sensor took longer than the scheduled update interval 0:00:05
2018-10-15 11:29:55 ERROR (MainThread) [homeassistant.core] Error doing job: Task exception was never retrieved
yield
r.content
2018-10-15 11:30:06 ERROR (MainThread) [homeassistant.core] Error doing job: Task exception was never retrieved
yield
r.content
2018-10-15 11:30:18 ERROR (MainThread) [homeassistant.core] Error doing job: Task exception was never retrieved
yield
r.content
2018-10-15 11:30:31 ERROR (MainThread) [homeassistant.core] Error doing job: Task exception was never retrieved
yield
