Hi guys, I have been trying for days to import my Home Assistant OS backup to my VMs in Unraid, I created VMs of Debian and Ubuntu in which I tried to install Home Assistant Supervised several times, now I followed this guide:
Obviously I don’t have to host Debian on Raspberry, but Debian is hosted on the Unraid VM, so I followed the steps in the section: “Section 2 - Install OS Agent, Docker and Dependencies”
WARNING, I had to download Docker version 20.10.11 because of the CGroup1 & CGroup2 issue (I watched this YouTuber’s video to see if version 20.10.11 was going: https://www.youtube.com/watch?v=ivBPS5-zi04&t)
Once I ascertained that the Docker 20.10.11 version was going I went to this site:
Index of linux/debian/dists/bullseye/pool/stable/amd64/
to download the correct Docker, ran the wget and dpkg command on Debian and then proceeded with the rest of the tutorial at: Installing Home Assistant Supervised on a Raspberry Pi using Debian 12
it all works, but once I import my Home Assistant OS backup to Home Assistant Supervised it doesn’t apply the full backup to me, but only those of the added components and I see them like that:
I can’t even start them, and I don’t understand why it gives all these problems with restoring the full backup, I also tried on Ubuntu desktop 20.04 emulated on Unraid, to follow this other guide:
but nothing, the full backup won’t load it.
I really tried everything, even using Home Assistant’s VMDK and qcow2 on Unraid.
I read that in theory I can restore the backup from Hassio Os to Supervised, but why won’t it go?
maybe it is because my Raspberry Pi 3 where I have Hassio Os is aarch64 and the system I want to import the backup to is Supervised x86_64?
I wouldn’t want the only way to get everything working is to emulate the Raspberry Pi on Ubuntu emulated by Unraid? (https://youtu.be/Y-FUvi1z1aU)
maybe system information can help:
Raspberry Pi 3:
| Version | core-2023.5.4 |
| Installation Type | Home Assistant OS |
| Development | false |
| Supervisor | true |
| Docker | true |
| User | root |
| Virtual Environment | false |
| Python Version | 3.10.11 |
| Operating System Family | Linux |
| Operating System Version | 6.1.21-v8 |
| CPU Architecture | aarch64 |
| Timezone | Europe/Rome |
| Configuration Directory | /config |
Home Assistant Community Store
| GitHub API | ok |
| GitHub Content | ok |
| GitHub Web | ok |
| GitHub API Calls Remaining | 5000 |
| Installed Version | 1.32.1 |
| Stage | running |
| Available Repositories | 1284 |
| Downloaded Repositories | 38 |
Home Assistant Cloud
| Logged In | false |
| Reach Certificate Server | ok |
| Reach Authentication Server | ok |
| Reach Home Assistant Cloud | ok |
Home Assistant Supervisor
| Host Operating System | Home Assistant OS 10.1 |
| Update Channel | stable |
| Supervisor Version | supervisor-2023.04.1 |
| Agent Version | 1.5.1 |
| Docker Version | 23.0.3 |
| Disk Total | 109.3 GB |
| Disk Used | 12.2 GB |
| Healthy | true |
| Supported | true |
| Board | rpi3-64 |
| Supervisor API | ok |
| Version API | ok |
| Installed Add-ons | Duck DNS (1.15.0), File editor (5.6.0), RPC Shutdown (2.4), Advanced SSH & Web Terminal (15.0.2), Studio Code Server (5.6.1), Home Assistant Google Drive Backup (0.110.4), Mosquitto broker (6.2.1), Samba share (10.0.2), AdGuard Home (4.8.6), Plex Media Server (3.2.4), Node-RED (14.2.1), VLC (0.2.0), NGINX Home Assistant SSL proxy (3.5.0), Ring-MQTT with Video Streaming (5.2.2) |
Dashboards
| Dashboards | 3 |
| Resources | 21 |
| Views | 48 |
| Mode | storage |
Recorder
| Oldest Run Start Time | May 19, 2023 at 11:56 AM |
| Current Run Start Time | May 30, 2023 at 5:48 PM |
| Estimated Database Size (MiB) | 2238.72 MiB |
| Database Engine | sqlite |
| Database Version | 3.40.1 |
Sonoff
| Version | 3.5.1 (122751c) |
| Cloud devices online | 27 / 27 |
| Local devices online | 26 / 26 |
Debian:
| Installation Type | Home Assistant Supervised |
| Supervisor | true |
| Docker | true |
| User | root |
| Operating System Version | 5.10.0-23-amd64 |
| CPU Architecture | x86_64 |
| Logged In | false |
| Host Operating System | Debian GNU/Linux 11 (bullseye) |
| Docker Version | 24.0.2 |
| Disk Total | 28.4 GB |
| Disk Used | 12.3 GB |
| Healthy | true |
| Supported | true |
| Version API | ok |
| Installed Add-ons | AdGuard Home (4.8.6), Advanced SSH & Web Terminal (15.0.2), Duck DNS (1.15.0), File editor (5.6.0), Home Assistant Google Drive Backup (0.110.4), Mosquitto broker (6.2.1), NGINX Home Assistant SSL proxy (3.5.0), Node-RED (14.2.1), Plex Media Server (3.2.4), RPC Shutdown (2.4), Ring-MQTT with Video Streaming (5.2.2), Studio Code Server (5.6.1), VLC (0.2.0), Samba share (10.0.2) |
Dashboards
| Dashboards | 1 |
| Resources | 0 |
| Mode | auto-gen |
Recorder
| Oldest Run Start Time | May 30, 2023 at 5:03 PM |
| Current Run Start Time | May 30, 2023 at 9:58 PM |
| Estimated Database Size (MiB) | 0.41 MiB |
