Hi all,
I’ve looked through a bunch of similar posts, and cannot find anything that might be causing this…
Here are the facts;
- It’s not a layer 2 issue, cable swapped, switch swapped, link lights ON on the Pi.
- IP is statically assigned via nmcli, so no dhcp/router issues to consider
- From CLI (logged in locally, to the host, not within the docker), HassIO host cannot ping local gateway (or beyond), and I cannot ping the Pi on local network.
As i only have local access and no SSH, output of nmcli below is a select few lines i’m hoping may show an issue or that all is well…
#nmcli connection show
HassOS default UUID ethernet eth0
#nmcli connection show "HassOS default"
connection.interface-name: --
802-3-ethernet.port: --
802-3-ethernet.mac-address: --
general.devices: eth0
general.state: activated
general.default: yes
IP4.ADDRESS[1]: 192.168.1.60/24
IP4.GATEWAY: 192.168.1.1
IP4.ROUTE[1]: dst = 192.168.1.0/24, nh = 0.0.0.0, mt = 100
IP4.ROUTE[2]: dst = 0.0.0.0, nh = 192.168.1.1, mt = 100
IP4.DNS: 1.1.1.1
Any advice on how to further troubleshoot this matter would be greatly appreciated.
Regards,
Nasha
