I’m getting some weird behavior with my HASSIO system. I’m trying to use it to automate some things on our farm. I’ve built and configured the system at home (different location and IP as the farm) and it works perfectly. Once I move it to the farm it will boot up and I can log in to the GUI. But if I reboot the system from the GUI HASSIO menu the system will essentially brick. I can ping the unit, but no GUI, no Samba, and no SSH.
At the farm location, I have the Raspberry Pi hardwired into an Asus RTN66R router that is serving as an access point. The router and modem are two miles away, we are beaming the signal via a point-to-point Ubiquiti system. So, the signal goes Modem>Router>Ubiquiti PTP>Access Point>RPi. We have a computer at the location the RPi is being installed. That computer is running BlueIris with security cameras. The speed is slow (1mb/s) but it works very reliably and can be accessed remotely.
I have all the ports that are needed by HASSIO forwarded in the router (to the RPi address) and modem (to the router address).
Could my network setup at the farm be causing the issue? Anything else I should be looking at?
I’m wondering if my DuckDNS/LetsEncrypt is causing some of the issues. I set it up with my home IP, would the LetsEncrypt cause issues if the RPi’s WAN ip address changes once moved to the farm? Although, I wouldn’t think that would cause it to “brick”. Could it be an issue with the slow speed (1mb/s)?
