complete Newbie
So I take the SD card out of my raspberry Pi, put it into my PC, search for the file called "configuration.yaml, then read that file using notepad?
complete Newbie
No. You connect to your Pi via Samba or FTP and look for a folder called “config” (usually on the root folder) and “configuration.yaml” is inside it.
What OS are you using?
On the SD card is hassio.
I’m on a Windows 10 PC.
Can you point me in the right direction for software for Windows 10 PC, to contact the raspberry Pi using either Samba or FTP please?
Any advice appreciated, Tremulous Tetra.
Open Windows Explorer and under “Network” find a share called “HASSIO”
this is what I get listed, no hassio
I am seem to be having a lot of problems, could it be because I have the raspberry Pi 3 connected to 1 of these
That could be the problem. Are you using fixed IP? If not try this:
“Optional - Setup the WiFi or static IP: On the SD-card, edit the system-connections/resin-sample file and follow the ResinOS howto.”
just got my daughter to plug it straight into the router (my hands are paralysed) and it still has the same problems.
I will have a look at your new setup option.
Thank you
back to the same problem, how do I edit those files?
So I take the SD card out of my raspberry Pi, put it into my PC, search for the file called “connection file”, then edit that file using notepad?
Edit the “system-connections/resin-sample” file with notepad.
Setting a static IP is possible by adding a few fields to the [ipv4] section of your connection file.
See:
https://docs.resin.io/deployment/network/2.0.0/#setting-a-static-ip
How would he connect via samba if he hasn’t got into it yet to install the add on?
There’s no password by default so you’ve either got further than your saying and added one yourself or something has gone very wrong with your install.
Either way, just erase your SD card and start from scratch.
Set up an IP reservation on your router for the pi’s MAC, far easier than messing about with the resin config.
I tend to lean towards the idea that something has gone very wrong with the install. The problem is I have no idea what.
All I have done is burned the programme from the website, which I have downloaded twice to make sure there was no problem with the 1st 1.
I then burned the program to the SD card with etcher.
Put the SD card in the raspberry Pi 3, and left it for half an hour.
I then go to my IP address for this device, which I find by looking on my router, with the :8123and I get the screen in my web browser which I posted earlier.
That’s it, that’s all I’d done.
I have also tried plugging the raspberry Pi Straight into my router, thinking the power line lan might be the problem. No change.
tried again downloading. Triedtwice burning it to the SD card, put it in the raspberry Pi, switched it on, with the network cable plugged straight into the router, and left for one hour. Same problem, the screen is asking for username and password.
The raspberry Pi 3 works fine with the normal raspbian.
I’ll jump in and try to help.
Just to be clear, for your Raspberry Pi 3, this is the file that should be downloaded and burned to the SD card with Etcher:
After you boot up the Pi and wait 30 mins or so, you should be able to access the installation by going into a web browser and typing:
The Home Assistant main screen should just load - there’s no password by default. I’m wondering if it’s asking for one because you’ve been accessing via IP address and not the hassio.local address.
yes that is the file I downloaded last night.ought to be absolutely sure, I will burn the 1 you gave me the link to now.
when I use the semicolo
http://hassio.local:81231
I get the error message;
Cannot reach this page
•Make sure the web address http://hassio.local:8123 is correct
•Search for this site on Bing
•Refresh the page
More information More information
Fix connection problems
Again just to be absolutely sure, the address is:
(that is, the port number is 8123)
Not:
(the port number is not 81231).
I’ve always managed to get straight in with the IP but I’ve always made sure it’s fixed before I start.
Not sure why TT is reluctant to do this?
Not sure if he’s reluctant or just inexperienced with Linux. At any rate the point of the hassio.local address is so that you don’t need to find the dhcp address after installation. And setting a dhcp reservation in the router is perfectly valid.
Point is, if he can access the login page then we’re past the point of needing to worry about static vs dynamic ip.
