k1282
September 1, 2018, 9:07pm
1
I just changed something in a custom .py file for a fix attempt and now after a restart, Hassio is not booting anymore.
I also do not have any backup (stupid, I know).
What options do I have to fix it?
I just need to get into the file in the Hassio file directory and reverse the change I made, at least I think that this will help here.
k1282
September 2, 2018, 11:12am
2
did some progress:
i put my sd card into a virtual box running ubuntu allowing me to read and backup all contents.
but i hoped to edit the custom component, which is not possible with read only rights. is there a way to achieve this?
i just want to avoid to create a new hassio image
k1282
September 2, 2018, 12:03pm
3
and i fixed it myself by using the following command on the folder I needed to edit:
sudo -i nautilus
long story:
As I do not have a Linux machine I installed oracle’s virtual box and downloaded and installed ubuntu on that virtual box.
I then installed the official oracle virtual box extension pack to enable accessing my usb drive attached to my windows PC via the virtual box
inserted my rpi hassio microsd
added the microsd as usb drive from within the virtual box settings
restarted ubuntu in order to show all folders on the microsd
per default only read access is available so I right clicked on the “home assistant” folder and selected to run with terminal
within terminal i just ran the following command in order to have write access:
sudo -i nautilus
