Hassio no longer see’s Conbee2 after supervisor upgrade, I am using zha integration not deconz. The line entry under hardware no longer shows either?
Mon Feb 10 2020 19:41:29 GMT-0500 (Eastern Standard Time)
Error setting up entry /dev/serial/by-id/usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2122921-if00 for zha
File "/usr/local/lib/python3.7/site-packages/serial/serialposix.py", line 244, in open
self.fd = os.open(self.portstr, os.O_RDWR | os.O_NOCTTY | os.O_NONBLOCK)
FileNotFoundError: [Errno 2] No such file or directory: '/dev/serial/by-id/usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2122921-if00'
File "/usr/src/homeassistant/homeassistant/config_entries.py", line 215, in async_setup
hass, self
File "/usr/src/homeassistant/homeassistant/components/zha/__init__.py", line 103, in async_setup_entry
await zha_gateway.async_initialize()
File "/usr/src/homeassistant/homeassistant/components/zha/core/gateway.py", line 125, in async_initialize
await radio.connect(usb_path, baudrate)
File "/usr/local/lib/python3.7/site-packages/zigpy_deconz/api.py", line 198, in connect
self._uart = await uart.connect(device, DECONZ_BAUDRATE, self)
File "/usr/local/lib/python3.7/site-packages/zigpy_deconz/uart.py", line 120, in connect
xonxoff=False,
File "/usr/local/lib/python3.7/asyncio/coroutines.py", line 120, in coro
res = func(*args, **kw)
File "/usr/local/lib/python3.7/site-packages/serial_asyncio/__init__.py", line 410, in create_serial_connection
ser = serial.serial_for_url(*args, **kwargs)
File "/usr/local/lib/python3.7/site-packages/serial/__init__.py", line 88, in serial_for_url
instance.open()
File "/usr/local/lib/python3.7/site-packages/serial/serialposix.py", line 247, in open
raise SerialException(msg.errno, "could not open port {}: {}".format(self._port, msg))
serial.serialutil.SerialException: [Errno 2] could not open port /dev/serial/by-id/usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2122921-if00: [Errno 2] No such file or directory: '/dev/serial/by-id/usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2122921-if00'
