I am having issues with HASSIO UI after upgrade to 0.8.1.6 where I can SSH to HA but can’t open UI. When I check the logs through SSH, I get below error.
During the initial logs, I am sure I saw the API was on 172.30.32.2 IP address but later down the logs, it trying to connect to 172.30.31.1 instead of 172.30.31.2.
18-11-06 05:02:58 INFO (MainThread) [hassio.misc.dns] Start DNS port forwarding for host add-ons
18-11-06 05:02:58 INFO (MainThread) [hassio.core] Ignore Hass.io auto updates on dev channel
18-11-06 05:02:58 INFO (MainThread) [hassio.api] **_Start API on 172.30.32.2_**
18-11-06 05:02:58 INFO (MainThread) [hassio.addons] Startup initialize run 0 add-ons
18-11-06 05:02:58 INFO (MainThread) [hassio.addons] Startup system run 2 add-ons
18-11-06 04:54:59 ERROR (MainThread) [hassio.api.proxy] Client error on WebSocket API Cannot connect to host 172.30.32.1:443 ssl:False [Connection refused].
18-11-06 04:55:04 INFO (MainThread) [hassio.api.proxy] Home Assistant WebSocket API request initialize
18-11-06 04:55:04 INFO (MainThread) [hassio.api.proxy] WebSocket access from a0d7b954_appdaemon3
18-11-06 04:55:04 ERROR (MainThread) [hassio.api.proxy] Client error on WebSocket API Cannot connect to host 172.30.32.1:443 ssl:False [Connection refused].
18-11-06 04:55:07 INFO (MainThread) [hassio.api.security] /supervisor/logs access from core_ssh
I have tried restarting router and then HA but still same. In fact did that for few times now.
Similar issue with Hassio 1.4.0 and HA 0.81.6 and RaspberryPi3: cannot start Home Assistant.
core-ssh:~# hassio ha logs
18-11-06 17:21:32 ERROR (MainThread) [hassio.homeassistant] Error on call https://172.30.32.1:8123/api/services/persistent_notification/create: Cannot connect to host 172.30.32.1:8123 ssl:None [Connection refused]
18-11-06 17:21:32 ERROR (MainThread) [hassio.api.proxy] Error on API for request services/persistent_notification/create
Error decoding json invalid character 'T' looking for beginning of value: Traceback (most recent call last):
File "/usr/local/lib/python3.6/runpy.py", line 193, in _run_module_as_main
"__main__", mod_spec)
File "/usr/local/lib/python3.6/runpy.py", line 85, in _run_code
exec(code, run_globals)
File "/usr/local/lib/python3.6/site-packages/homeassistant/__main__.py", line 397, in <module>
sys.exit(main())
File "/usr/local/lib/python3.6/site-packages/homeassistant/__main__.py", line 371, in main
args = get_arguments()
File "/usr/local/lib/python3.6/site-packages/homeassistant/__main__.py", line 103, in get_arguments
import homeassistant.config as config_util
File "/usr/local/lib/python3.6/site-packages/homeassistant/config.py", line 15, in <module>
from homeassistant import auth
File "/usr/local/lib/python3.6/site-packages/homeassistant/auth/__init__.py", line 16, in <module>
from .mfa_modules import auth_mfa_module_from_config, MultiFactorAuthModule
File "/usr/local/lib/python3.6/site-packages/homeassistant/auth/mfa_modules/__init__.py", line 10, in <module>
from homeassistant import requirements, data_entry_flow
File "/usr/local/lib/python3.6/site-packages/homeassistant/requirements.py", line 10, in <module>
import pkg_resources
File "/usr/local/lib/python3.6/site-packages/pkg_resources/__init__.py", line 35, in <module>
import plistlib
File "/usr/local/lib/python3.6/plistlib.py", line 65, in <module>
from xml.parsers.expat import ParserCreate
File "/usr/local/lib/python3.6/xml/parsers/expat.py", line 4, in <module>
from pyexpat import *
ImportError: Error relocating /usr/local/lib/python3.6/lib-dynload/pyexpat.cpython-36m-arm-linux-gnueabihf.so: XML_SetCharacterDataHandler: symbol not found
