noxx
(Ralf B)
1
i ve installed “Let’s Encrypt”. Configuration was ok, but after
reboot i ve no WebGUI. Perhaps anyone can help. HASSIO should run:
core-ssh:~# hassio ha info
"result": "ok",
"data": {
"version": "0.71.0",
"last_version": "0.71.0",
"machine": "raspberrypi3",
"image": "homeassistant/raspberrypi3-homeassistant",
"custom": false,
"boot": true,
"port": 8123,
"ssl": false,
"watchdog": true,
"wait_boot": 600
If i try to open my page (IP:8123) the page shows “This website is not accessible”.
noxx
(Ralf B)
2
update:
it works, if i disable ssl_xxx
http:
api_password: !secret http_password
# DuckDNS / LetsEncrypt
# base_url: 1234.duckdns.org:8123
# ssl_certificate: /ssl/fullchain.pem
# ssl_key: /ssl/privkey.pem
with this:
http:
ive no WebGUI
Your base URL should be https://1234 etc for starters and you have to use https internally too.
noxx
(Ralf B)
4
you mean like this?
http:
base_url: https://1234.duckdns.org:8123
Yep. Would be useful if you also posted your config from the add-on and confirmed what port you forwarded on your router.
It doesn’t look as if LE is installed as SSL does not show true like mine
"result": "ok",
"data": {
"custom": false,
"boot": true,
"port": 8123,
"ssl": true,
"watchdog": true,
"wait_boot": 600
I just installed DuckDNS which does the LE Cert at the same time. The LE add on is just for renewing.
Add the DuckDNS add on and try again.
