Hassio node red and ssl help!
Please can someone do a step by step guide to set this up with duckdns, I can log into details red after I forward port 1880 but keep getting error that it can’t connect to hass… Tearing what little hair I have out, getting ready to launch this rpi3 into orbit!
same problem here …
Did you figure out ?
I am able to log in using the dyndyns but when Home Assistant is trying to connect to Node-Red get this message:
0|node-red | 2 Jun 14:34:19 - [error] [server:Home Assistant] Home assistant connection failed with error: Connection to home assistant could not be established with config: https://dyndyns <password redacted>
Don’t use your dyndns name in node-red. Use the hassio API proxy address of http://hassio/homeassistant instead.
Hi @NotoriousBDG thanks for the tip , but I am not using hassio I am using hassbian
I managed to fix the problem using my dyndns:8123
