thuva
(Thuva)
March 25, 2024, 8:26pm
1
I got a power cut and then I was not able to login to Hassio. I tried to connect the PI to the screen and checked the error:
it was not booting and failing with error
I have SD with hassio os.
Could be that PI SD card reader is not working? I open the SD card in a windows and the files are there.
francisp
(Francis)
March 26, 2024, 7:16am
2
Card did not respond to voltage select!
That message means it cannot talk to the SD card at all. The first thing u-boot does is try to read the voltage select registers, so it is failing on the first SD card command.
Try to disconnect everything from your usb, and then boot. Maybe it is just not enough power.
thuva
(Thuva)
March 26, 2024, 4:33pm
3
I tried to remove everything expect HDMI, same error. Also I tried to remove the HDMI and attach later. Same error.
Edit:
I tried to add in another RPI and got the same error. So card is broken? but when I connect to SD card to pc it works.
dawaman
(CUNY)
September 6, 2024, 6:13pm
4
did you found any solution ?
d0h0
(d0h0)
April 2, 2025, 9:08am
5
I also switched the power supply to a notebook charger, but that did not help. Reinstalling …
