Hassio not coming back up after power outage
Im running latest release of Hassio on a RaspberryPi3
After power failure it will not come back up. I have installed the Samba share and are able to access all the files. but it seems like the front end is not coming back up.
Im new to HA, so all help is appreciated.
Cheers
P
Any log errors? Also try unplugging the Pi and plugging it back in. And just so we’re clear, you can access the files in HA, the frontend just isn’t loading?
I forgot to save the log. And ended up with a clean install.
Yes i could access the files from the shared valume (samba).
I will make sure to share the log if it happens again (im sure it will, third time it happend, and third time)
I used to have this problem when I was running HA on a Mac, the database file would corrupt when the power went out and only way to get going again was to delete it and let it build a new one.
Using a Pi 3 now which doesn’t seem to have the same issue.
