Hassio not loading, neither do i have ssh access
hi,
i am running the current version of hassio… well i upgraded yesterday and i think since then i have not been able to use HA … i get ping responses on the pi IP address however, ssh says connection refused.
also ran a port scan against this and i only see port 22222 open on the port scan.
i am stuck w/out HA please help.
I read some of the messages that pointed to a low powered USB PS / networking issues with a new install…
i had mine very stable till yesterday for maybe close to a year now…
please help.
thanks,
Jay
seems i might have to add a key for this port and log into it to troubleshoot… per below…
https://developers.home-assistant.io/docs/en/hassio_debugging.html
seems i am out of space…
thoughts on if i can delete any of the below? till i get a larger sd card
root@hassio:/tmp# df -h
Filesystem Size Used Avail Use% Mounted on
devtmpfs 481M 0 481M 0% /dev
/dev/mmcblk0p3 295M 217M 62M 78% /
/dev/disk/by-label/resin-state 19M 202K 17M 2% /mnt/state
tmpfs 487M 0 487M 0% /dev/shm
tmpfs 487M 5.6M 481M 2% /run
tmpfs 487M 0 487M 0% /sys/fs/cgroup
tmpfs 487M 0 487M 0% /tmp
tmpfs 487M 32K 487M 1% /var/volatile
/dev/mmcblk0p1 40M 26M 15M 64% /mnt/boot
/dev/mmcblk0p6 14G 14G 0 100% /mnt/data
