Receiving all sorts of errors in log
2018-01-02 16:21:19 INFO (MainThread) [homeassistant.core] Bus:Handling <Event state_changed[L]: entity_id=persistent_notification.invalid_config, old_state=<state persistent_notification.invalid_config=notifying; title=Invalid config, message=The following components and platforms could not be set up:
- [http](https://home-assistant.io/components/http/)
- [api](https://home-assistant.io/components/api/)
- [websocket-api](https://home-assistant.io/components/websocket_api/)
- [system-log](https://home-assistant.io/components/system_log/)
- [frontend](https://home-assistant.io/components/frontend/)
- [history](https://home-assistant.io/components/history/)
- [config](https://home-assistant.io/components/config/)
- [media-player](https://home-assistant.io/components/media_player/)
- [camera](https://home-assistant.io/components/camera/)
- [logbook](https://home-assistant.io/components/logbook/)
- [google-assistant](https://home-assistant.io/components/google_assistant/)
- [panel-iframe](https://home-assistant.io/components/panel_iframe/)
- sensor.history_stats
- [zwave](https://home-assistant.io/components/zwave/)
- [conversation](https://home-assistant.io/components/conversation/)
- [cloud](https://home-assistant.io/components/cloud/)
- [tts](https://home-assistant.io/components/tts/)
not sure where to look for
in chrome I receive this
Impossibile raggiungere il sito
Connessione negata da 192.168.1.12.
Cerca 192 168 8123 con Google
ERR_CONNECTION_REFUSED
sjee
January 2, 2018, 3:39pm
4
Did you change your config?
xstrex
January 2, 2018, 3:46pm
5
Please post your config (after redacting personal information).
sjee
January 2, 2018, 3:51pm
6
I see in this other topic you’ve been screwing up things Isn’t it easier to restore a backup?
I took out api_password and ssl_certificate and ssl_ley and now is working … before they were there and was working, strange
http:
# Uncomment this to add a password (recommended!)
# api_password: !secret api_password
# ssl_certificate: /ssl/fullchain.pem
# ssl_key: /ssl/privkey.pem
sjee
January 2, 2018, 3:58pm
8
Strange, but aren’t you missing a base_url:
Jbcook
(Joe Cook)
January 2, 2018, 3:59pm
9
I’m sure this isn’t related. But this morning I was at work, editing some entity names etc. in the hassio configuration panel remotely via ssl and duckdns. Suddenly this afternoon I cannot get to my hassio installation remotely at all. I’ll have to check the logs when I get home but doesn’t make any sense!
sjee
January 2, 2018, 4:05pm
10
If you make a mistake in your configuration hassio might not start. In general it’s better make sure you also have direct access to the file system when editing the configuration.
Jbcook
(Joe Cook)
January 2, 2018, 4:07pm
11
Sorry, to be clear. Not editing the configuration.yaml but instead using the hassio frontend. This shouldn’t have triggered a reboot or anything so it should stick be up and running as far as I can tell.
Jbcook
(Joe Cook)
January 2, 2018, 4:11pm
12
Perhaps this could be happening?
My certificate didnt autorenew as I thought it would and now I cant access my Home-assistant unless I comment out the certificate lines of the configuration file.
I am running Hassio. What can I do to renew the certificate manually in some way?
sjee
January 2, 2018, 4:19pm
13
This is the same as editing the configuration.yaml. If you applied the config it might fail.
A certificate renewal fail right after you edit the config…
Jbcook
(Joe Cook)
January 2, 2018, 4:28pm
14
Ah, didn’t realise that, assumed it wouldn’t need a reboot. Must be that then I suppose!
Jbcook
(Joe Cook)
January 2, 2018, 4:38pm
15
Strangely, without any intervention from myself, it’s now up and running. Log shows no reason for shutdown, but it started at 4:17pm apparently.
