Hassio is a docker installation can be installed in any Linux system. Addons are their docker based plugin system.
Many of the addons can be installed in other Home Assistant installations. I have Configurator installed on my virtualenv install, for instance.
My opinion is that, even on a Raspberry Pi, it is better to install Hassio on a Linux OS rather than use the HassOS image. I had stability issue with HassOs in a VM.
I followed the steps in the official installation guide for Linux. But since I don’t know much about Linux how do I find the address Hassio is now running on? Tried Hassio.local:8123 which didn’t work. And will the docker container automatically start when Linux is rebooted?
In many links systems the command ip addr will tell you the ip address. What Linux system did you choose? ? Here is the output on Raspian for a wired ip address of 192.168.131.178. (eth0) Wireless would be under wlan0. The poer designations vary depending on the Linux variant.
pi@hass:~$ ip addr
1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group default qlen 1000
link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
inet 127.0.0.1/8 scope host lo
valid_lft forever preferred_lft forever
inet6 ::1/128 scope host
2: eth0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc pfifo_fast state UP group default qlen 1000
link/ether b8:27:eb:18:c5:eb brd ff:ff:ff:ff:ff:ff
inet 192.168.131.178/24 brd 192.168.131.255 scope global eth0
inet6 fe80::bcc2:ebe0:9072:54c2/64 scope link
3: wlan0: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc pfifo_fast state DOWN group default qlen 1000
link/ether b8:27:eb:4d:90:be brd ff:ff:ff:ff:ff:ff
I think the config directory is in /usr/share/hassio by default.
There is a file /etc/hassio.json listing the location.
I think you can safely ignore that Samba warning.
I think they are asking if they can install Hassio along side Home Assistant.
The answer is that, using default settings, it cannot be done since they share the same network ports.
Even when it is possible, is would not be easy and likely not worth the extra effort.
What features do you see in Hassio that are not present in Home Assistant? Many things equivalent to the Hassio addons can be added to Home Assistant. I have the Configuration tool, for instance, in my virtualenv Home Assistant.
You DON’T need the add-on. You use the component which is available on every platform or the cloud component if you don’t know how to forward ports or setup SSL
