I’ trying to setup Hassio on docker running on a Ubuntu server. Have setup docker etc and using docker-compose am getting the error message
“pull access denied for homeassistant/home_assistant, repository does not exist or may require ‘docker login’”
when running the docker-compose file below
version: '3'
services:
homeassistant:
container_name: home-assistant
image: homeassistant/home_assistant:latest
restart: unless-stopped
devices:
- /dev/ttyACM0:/dev/ttyACM0
- /dev/serial/by-id/usb-RFXCOM_RFXtrx433_A1YVKF2V-if00-port0:/dev/serial/by-id/usb-RFXCOM_RFXtrx433_A1YVKF2V-if00-port0
- /dev/ttyUSB1:/dev/ttyUSB1
environment:
- TZ=Europe/London
- LOCAL_NETWORK=192.168.86.0/24
network_mode: host
hostname: etoufee
ports:
- "8123:8123"
volumes:
- /media/ha:/config:rw
- /etc/localtime:/etc/localtime:ro
I know the ports declaration isn’t required, but wondered if anyone can see if there is anything else that might be contributing to the error message?
