Hassio on proxmox dead. how to restore from snapshot?
i was playing around with the config and after restarting HA, it wont load the GUI. I can’t even see the config folder on my network. i know Proxmox loaded it and i see Hassio is on based its IP:
Is there anyway i can have Hassio load up the last known working snapshot? like a dummy, i have the snapshot on Hassio but i didnt download it to my laptop!
when i click on console in Proxmox, this is all i see:
pls help
Can you use the CLI? https://www.home-assistant.io/hassio/commandline/
Click inside the Console window and press Enter, is a login-prompt shown after that?
yes, i got the login prompt and then the screen flashes by. the login prompt does not stay. if i press Enter again, i will see the prompt again.
Great!
Enter root at the login-prompt and then you should be able to use the CLI-commands, like snapshots.
Good luck repairing your system!
