Hassio on rasperry pi2
Good morning,
i found my old raspberry pi2 i wanted to use it with hassio, but i am facing some problems:
  • if I use the haos_rpi2-6.2.img.xz installation, I am in the supervisor environment, but I cannot install any additional components and therefore I have no possibility to use ssh and I am blocked;
  • if, on the other hand, I use the Home Assistant Core installation on a Raspian system, I cannot in any way add Hacs and therefore I get stuck.
    You can help me? Thanks.
You should be able to add add-ons, and custom components.
You can install hacs in a venv (HA Core)
A third option is to install HA Supervised.
With HAOS you have a lot of addons to supply any additional components that you need, and if not, you can create your addons.
