Seems like something is going on with setting the region:
Any ideas on how to fix it ?
[56298.525189] cfg80211: DFS Master region: unset
[56298.525198] cfg80211: (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp), (dfs_cac_time)
[56298.525212] cfg80211: (2402000 KHz - 2472000 KHz @ 40000 KHz), (N/A, 2000 mBm), (N/A)
[56298.525227] cfg80211: (2457000 KHz - 2482000 KHz @ 20000 KHz, 92000 KHz AUTO), (N/A, 2000 mBm), (N/A)
[56298.525239] cfg80211: (2474000 KHz - 2494000 KHz @ 20000 KHz), (N/A, 2000 mBm), (N/A)
[56298.525252] cfg80211: (5170000 KHz - 5250000 KHz @ 80000 KHz, 160000 KHz AUTO), (N/A, 2000 mBm), (N/A)
[56298.525267] cfg80211: (5250000 KHz - 5330000 KHz @ 80000 KHz, 160000 KHz AUTO), (N/A, 2000 mBm), (0 s)
[56298.525280] cfg80211: (5490000 KHz - 5730000 KHz @ 160000 KHz), (N/A, 2000 mBm), (0 s)
[56298.525292] cfg80211: (5735000 KHz - 5835000 KHz @ 80000 KHz), (N/A, 2000 mBm), (N/A)
[56298.525304] cfg80211: (57240000 KHz - 63720000 KHz @ 2160000 KHz), (N/A, 0 mBm), (N/A)
[56302.453570] cfg80211: Regulatory domain changed to country: NO
[56302.453593] cfg80211: DFS Master region: ETSI
[56302.453602] cfg80211: (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp), (dfs_cac_time)
[56302.453616] cfg80211: (2400000 KHz - 2483500 KHz @ 40000 KHz), (N/A, 2000 mBm), (N/A)
[56302.453631] cfg80211: (5150000 KHz - 5250000 KHz @ 80000 KHz, 200000 KHz AUTO), (N/A, 2301 mBm), (N/A)
[56302.453645] cfg80211: (5250000 KHz - 5350000 KHz @ 80000 KHz, 200000 KHz AUTO), (N/A, 2000 mBm), (0 s)
[56302.453658] cfg80211: (5470000 KHz - 5795000 KHz @ 160000 KHz), (N/A, 2698 mBm), (0 s)
[56302.453670] cfg80211: (5815000 KHz - 5850000 KHz @ 35000 KHz), (N/A, 3301 mBm), (0 s)
[56302.453683] cfg80211: (17100000 KHz - 17300000 KHz @ 200000 KHz), (N/A, 2000 mBm), (N/A)
[56302.453695] cfg80211: (57000000 KHz - 66000000 KHz @ 2160000 KHz), (N/A, 4000 mBm), (N/A)
[56720.266850] brcmfmac: brcmf_cfg80211_reg_notifier: not a ISO3166 code
[56720.266881] cfg80211: World regulatory domain updated:
[56720.266890] cfg80211: DFS Master region: unset
[56720.266899] cfg80211: (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp), (dfs_cac_time)
[56720.266914] cfg80211: (2402000 KHz - 2472000 KHz @ 40000 KHz), (N/A, 2000 mBm), (N/A)
[56720.266928] cfg80211: (2457000 KHz - 2482000 KHz @ 20000 KHz, 92000 KHz AUTO), (N/A, 2000 mBm), (N/A)
[56720.266941] cfg80211: (2474000 KHz - 2494000 KHz @ 20000 KHz), (N/A, 2000 mBm), (N/A)
[56720.266954] cfg80211: (5170000 KHz - 5250000 KHz @ 80000 KHz, 160000 KHz AUTO), (N/A, 2000 mBm), (N/A)
[56720.266968] cfg80211: (5250000 KHz - 5330000 KHz @ 80000 KHz, 160000 KHz AUTO), (N/A, 2000 mBm), (0 s)
[56720.266980] cfg80211: (5490000 KHz - 5730000 KHz @ 160000 KHz), (N/A, 2000 mBm), (0 s)
[56720.266993] cfg80211: (5735000 KHz - 5835000 KHz @ 80000 KHz), (N/A, 2000 mBm), (N/A)
[56720.267005] cfg80211: (57240000 KHz - 63720000 KHz @ 2160000 KHz), (N/A, 0 mBm), (N/A)
[56726.520154] cfg80211: Regulatory domain changed to country: NO
[56726.520178] cfg80211: DFS Master region: ETSI
[56726.520187] cfg80211: (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp), (dfs_cac_time)
[56726.520202] cfg80211: (2400000 KHz - 2483500 KHz @ 40000 KHz), (N/A, 2000 mBm), (N/A)
[56726.520217] cfg80211: (5150000 KHz - 5250000 KHz @ 80000 KHz, 200000 KHz AUTO), (N/A, 2301 mBm), (N/A)
[56726.520231] cfg80211: (5250000 KHz - 5350000 KHz @ 80000 KHz, 200000 KHz AUTO), (N/A, 2000 mBm), (0 s)
[56726.520244] cfg80211: (5470000 KHz - 5795000 KHz @ 160000 KHz), (N/A, 2698 mBm), (0 s)
[56726.520256] cfg80211: (5815000 KHz - 5850000 KHz @ 35000 KHz), (N/A, 3301 mBm), (0 s)
[56726.520269] cfg80211: (17100000 KHz - 17300000 KHz @ 200000 KHz), (N/A, 2000 mBm), (N/A)
[56726.520281] cfg80211: (57000000 KHz - 66000000 KHz @ 2160000 KHz), (N/A, 4000 mBm), (N/A)
[59305.556851] brcmfmac: brcmf_cfg80211_reg_notifier: not a ISO3166 code
[59305.556874] cfg80211: World regulatory domain updated:
[59305.556883] cfg80211: DFS Master region: unset
[59305.556892] cfg80211: (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp), (dfs_cac_time)
[59305.556907] cfg80211: (2402000 KHz - 2472000 KHz @ 40000 KHz), (N/A, 2000 mBm), (N/A)
[59305.556921] cfg80211: (2457000 KHz - 2482000 KHz @ 20000 KHz, 92000 KHz AUTO), (N/A, 2000 mBm), (N/A)
[59305.556933] cfg80211: (2474000 KHz - 2494000 KHz @ 20000 KHz), (N/A, 2000 mBm), (N/A)
[59305.556947] cfg80211: (5170000 KHz - 5250000 KHz @ 80000 KHz, 160000 KHz AUTO), (N/A, 2000 mBm), (N/A)
[59305.556961] cfg80211: (5250000 KHz - 5330000 KHz @ 80000 KHz, 160000 KHz AUTO), (N/A, 2000 mBm), (0 s)
[59305.556973] cfg80211: (5490000 KHz - 5730000 KHz @ 160000 KHz), (N/A, 2000 mBm), (0 s)
[59305.556985] cfg80211: (5735000 KHz - 5835000 KHz @ 80000 KHz), (N/A, 2000 mBm), (N/A)
[59305.556997] cfg80211: (57240000 KHz - 63720000 KHz @ 2160000 KHz), (N/A, 0 mBm), (N/A)
[59311.824113] cfg80211: Regulatory domain changed to country: NO
[59311.824135] cfg80211: DFS Master region: ETSI
[59311.824145] cfg80211: (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp), (dfs_cac_time)
[59311.824160] cfg80211: (2400000 KHz - 2483500 KHz @ 40000 KHz), (N/A, 2000 mBm), (N/A)
[59311.824175] cfg80211: (5150000 KHz - 5250000 KHz @ 80000 KHz, 200000 KHz AUTO), (N/A, 2301 mBm), (N/A)
[59311.824188] cfg80211: (5250000 KHz - 5350000 KHz @ 80000 KHz, 200000 KHz AUTO), (N/A, 2000 mBm), (0 s)
[59311.824201] cfg80211: (5470000 KHz - 5795000 KHz @ 160000 KHz), (N/A, 2698 mBm), (0 s)
[59311.824214] cfg80211: (5815000 KHz - 5850000 KHz @ 35000 KHz), (N/A, 3301 mBm), (0 s)
[59311.824226] cfg80211: (17100000 KHz - 17300000 KHz @ 200000 KHz), (N/A, 2000 mBm), (N/A)
[59311.824238] cfg80211: (57000000 KHz - 66000000 KHz @ 2160000 KHz), (N/A, 4000 mBm), (N/A)
[60086.902243] Bluetooth: hci0: Frame reassembly failed (-84)
[60088.896206] Bluetooth: hci0 command 0x0419 tx timeout
