My Hassio restarts every ~5 minutes and I can’t figure out why.
Ubuntu 18.10
Docker - containers remain up
Supervisor 209
Home Assistant 0.106.6
Home Assistant Log:
2020-03-11 21:55:13 WARNING (MainThread) [homeassistant.components.device_tracker] The 'hide_if_away' option (with value 'False') is deprecated, please remove it from your configuration. This option will become invalid in version 0.107.0
2020-03-11 21:55:13 INFO (SyncWorker_9) [homeassistant.loader] Loaded homekit from homeassistant.components.homekit
2020-03-11 21:55:13 INFO (MainThread) [homeassistant.components.stream] Stopped stream workers.
2020-03-11 21:55:13 INFO (MainThread) [homeassistant.components.websocket_api.http.connection.139845591023184] Connection closed by client
2020-03-11 21:55:13 INFO (MainThread) [homeassistant.components.websocket_api.http.connection.139845587808400] Connection closed by client
2020-03-11 21:55:18 ERROR (MainThread) [homeassistant.components.hassio.handler] Client error on /homeassistant/restart request None
Supervisor:
20-03-12 01:55:13 INFO (SyncWorker_18) [supervisor.docker.interface] Restart homeassistant/qemux86-64-homeassistant
20-03-12 01:55:13 INFO (MainThread) [supervisor.api.proxy] Home Assistant WebSocket API error: Received message 8:1000 is not str
20-03-12 01:55:13 INFO (MainThread) [supervisor.api.proxy] Home Assistant WebSocket API connection is closed
20-03-12 01:55:18 INFO (MainThread) [supervisor.api.proxy] Home Assistant WebSocket API request initialize
