Hassio Share directory access via SD card
I am storing images captured via a USB camera to the share directory on my Hassio instance. Copying them over the Samba share is very slow so I assumed I would be able to put the SD card in my Mac and copy the files accross. However I cannot see the share directory - is it correct that it’s not accessible directly via the SD card?
Cheers
I do not know a lot about mac’s but can’t you just acces your SD through you network? Extra benefit is that you don’t have to remove you SD from you device.
I have several hundred images, I want to transfer directly via USB
Do you have ‘hidden folders’ functionality on or off on your mac?
It is on. I am going to re-flash my Hassio as it is running slowly and behaving odd.
